Hi bsgursta,
Thanks for you interest in using FreeRTOS+TCP.
Have you checked your heap function, does it work properly?
Which heap_?.c module do you use?
Do you get a clear warning/assert when pvPortMalloc() fails?
Is ICMP/ping enabled? Can you ping your STM32F7?
Can you ping from your STM32F7 to your server at 10.x.x.x?
Here I see a minor typo:
/*connect to remote socket */
- if( FreeRTOS_connect( xSocket, &xRemoteAddress, ( sizeof( xRemoteAddress ) == 0 ) ) )
+ if( FreeRTOS_connect( xSocket, &xRemoteAddress, sizeof( xRemoteAddress ) ) == 0 )
SEGGER_RTT_printf( 0, "Connected\n" );
The above is no problem because xAddressLength is ignored inside FreeRTOS_connect().
The following code needs a change:
xBytesSent = FreeRTOS_send( xSocket, pcBuffer, xLen, flags );
if( xBytesSent <= 0 )
xAlreadyTransmitted += xBytesSent;
printf( "Bytes not send" );
The return value of FreeRTOS_send() is as follows:
>0 : the number of bytes sent
= 0 : zero bytes have been sent, no error
< 0 : -EINVAL, -ENOMEM, -ENOTCONN, -EINTR, -EWOULDBLOCK.
Please note that EINTR and EWOULDBLOCK are non-fatal error.
You can find the errno declarations in frertos/include/projdefs.h
Are you sure that you want to pass a pointer to a socket (which is a pointer)?
Later when calling recv(), you forget to de-reference the pointer in FreeRTOS_recv(socket_closing, ...).
void vshutdownSocket(Socket_t *socket_closing, char *pcTxBuffer, const size_t xTotalLengthToSend )
//check if the shutdown is happening
if(shutdown){
FreeRTOS_closesocket(*socket_closing);
printf("socket shutdown");
else{
printf("socket not shutdown");
I think that a function called vshutdownSocket() should promise to always close the socket, and thus free the memory space.
Calling shutdown makes sure that the closure of the connection is initiated. It is started by sending the FIN flag. When acknowledged, the socket may be destroyed by calling closesocket().
When a recv() function returns an error, it is useless to call shutdown and wait for an acknowledge.
“Gracefully” shutting down a socket is not an obligation, although it has many advantages. It makes sure that the peer also closes the socket, thus freeing space. Think of an HTTP server with limited resources.
Before shutting down the TCP connection, I would normally change the socket’s RX timeout (making it small, e.g. 10 ms), and not call vTaskDelay(). Calling FreeRTOS_recv() will already do a delay.
Next steps:
Although it might not solve your hard-fault, could you make the proposed changes?
I can see that FreeRTOS_connect() is called by vSendTCP(), but can you show how vSendTCP() is called?
Where does ConfigTCPClientSocket() come in?
Cheers
