Due to the way a wifi module doesn’t connect immediately, if dhcp tries too soon things don’t work as expected. Perhaps I’m doing something wrong here, but to mitigate this, I did this:
in FreeRTOS_DHCP.h
typedef enum eDHCP_ANSWERS
eDHCPDelay, /* <----- Delay option */
eDHCPContinue, /* Continue the DHCP process */
eDHCPUseDefaults, /* Stop DHCP and use the static defaults. */
eDHCPStopNoChanges, /* Stop DHCP and continue with current settings. */
} eDHCPCallbackAnswer_t;
in FreeRTOS_DHCP.c
in void vDHCPProcess( BaseType_t xReset )
This hook allows me to delay DHCP until the network interface is completely ready.
case eWaitingSendFirstDiscover :
/* Ask the user if a DHCP discovery is required. */
#if( ipconfigUSE_DHCP_HOOK != 0 )
eAnswer = xApplicationDHCPHook( eDHCPPhasePreDiscover, xNetworkAddressing.ulDefaultIPAddress );
if( eAnswer == eDHCPDelay){
/* Do nothing, delay */
} else if( eAnswer == eDHCPContinue )
#endif /* ipconfigUSE_DHCP_HOOK */
This hook allows me to do something if DHCP fails.
if( xGivingUp != pdFALSE )
/* xGivingUp became true either because of a time-out, or because
xApplicationDHCPHook() returned another value than 'eDHCPContinue',
meaning that the conversion is canceled from here. */
eAnswer = xApplicationDHCPHook( eDHCPPhaseFailed, xNetworkAddressing.ulDefaultIPAddress );
Any comments on this approach, could this be considered, or is there another way to get there?
For people using DHCP, you solve a problem, because you can delay the DHCP processing. But what if another user doesn’t enable DHCP. His first messages would get lost.
When the IP-task starts up, it will call xNetworkInterfaceInitialise() every 3 seconds until it returns the value pdPASS.
Does your WiFi driver know when the interface is ready to exchange messages?
I would propose to change xNetworkInterfaceInitialise() and have it return a pdPASS as soon as the WiFi interface is ready to transmit messages. Could that be done?
Are you saying that this is already in place now? I think for this to work properly that prvProcessNetworkDownEvent isn’t going to be able to call FreeRTOS_NetworkDown() every time pdFALSE is returned? Otherwise this would work fine I think.
That is the way how it works. The function prvProcessNetworkDownEvent() keeps on sending a message of the type eNetworkDownEvent.
Do you mean iptraceDHCP_REQUESTS_FAILED_USING_DEFAULT_IP_ADDRESS() ?
You can set that macro in your FreeRTOSIPConfig.h. But note that there is not a second chance for DHCP, other than reboot the device.
The most important thing here is xNetworkInterfaceInitialise() : only the driver can know exactly when the link is fully operational.
