Hi! I ask for tips in writing a client with connection control. The server device accepts and responds to commands from the client, but sometimes the server can send data without a request from the client. As I understand it, the FreeRTOS_issocketconnected function simply checks the flags and not the actual presence of a connection (if, for example, the connection was physically interrupted).
The code examples usually work opening - sending-closing, but I need to keep the connection open and check that it is physically established.
You could use keep alive probing (when connection is idle)
See ipconfigTCP_KEEP_ALIVE(_INTERVAL)
here:
This is a common feature of (other) TCP stacks.
Or implement your own heartbeat mechanism.
Thankk you! Will this function change the socket flag in case the connection is lost? And will the issocketconnected function return the correct value?
I think so. See the documentation:
If FreeRTOS-Plus-TCP does not receive a reply to a keep alive message then the connection will be broken and the socket will be marked as closed.
Subsequent FreeRTOS_recv()
calls on the socket will return -pdFREERTOS_ERRNO_ENOTCONN
The function FreeRTOS_issocketconnected()
indeed only checks the flags.
When keep-alive is enabled, the socket will send a standard keep-alive packet at a regular interval. When not answered, the connection will be broken with a shutdown.
Then it is good to also call FreeRTOS_recv()
and see what it returns.
If you use any of the application hooks (eg. FREERTOS_SO_TCP_CONN_HANDLER
) or select()
, your application will be woken up.
It is also good to enable ipconfigTCP_HANG_PROTECTION(_TIME)
I’m also a fan of leaving TCP connections open continuously, and send/receive packets asynchronously.
Thanks a lot! Would you recommend a windows application that can send raw tcp SYN FIN ACK packets for testing
