downytif wrote on Tuesday, September 29, 2009:
I’m trying to make my application work and I encounter issues like this one. First, I’m using FreeRTOS on a AVR32 UC3 chip. I use the Atmel framwork 1.4.
I currenty have 3 task running. The main one, a startup one, the main LWIP one.
I goes like this:
main.cpp
// Start the Startup Task. Done this way to start the scheduler as soon as possible!
// The reason is simple… The scheduler enables the interrupts (used by the serial communication).
xTaskCreate(StartupTask, (const signed portCHAR*) "STARTUP_TASK", TASK_STARTUP_STACK_SIZE, (void*)pRadarUnit, TASK_STARTUP_PRIORITY, NULL);
// Start the OS scheduler. It should never return from there.
vTaskStartScheduler();
return 0;
So, my main task is starting a STARTUP task that will create and initialize all modules. At this point, my LWIP task is already started. Then, my startup task will try to create another task. The problem I have is that inside
signed portBASE_TYPE xTaskCreate( pdTASK_CODE pvTaskCode, const signed portCHAR * const pcName, unsigned portSHORT usStackDepth, void *pvParameters, unsigned portBASE_TYPE uxPriority, xTaskHandle *pxCreatedTask )
the application hangs on taskYIELD(); My RTOS is configured in preemtive mode.
Not sure what to do next… If anyone can help me…
Thanks
