I am trying to use FreeRTOS on a dsPIC33CH512MP508 MCU, but I am experiencing some weird behavior.
At the moment I am testing a dummy project to simply blink two LEDs every 5 (LED0) and 15 ms (LED1) respectively using a tick time base of 1 ms. However, it seems every time one of these two tasks is resumed to toggle its related output line, this somehow causes the tick interrupt to be triggered a second time. This in turn causes the LED periodicity to be early.
In the attached image you can find an oscilloscope screenshot showing the issue. The yellow and green signals represent LED0 and LED1 respectively. In its first cycle LED0 is early (4 ms) since one LED1 edge occured in between. Similarly, LED1 is early (12 ms) since several LED0 events occured during its cycle.
Plus, the blue signal is a debug toggling line placed inside the tick-timer ISR. As can be seen, each time an LED task is resumed, the ISR is for some reason retriggered.
I also tried multiple variations, but the behavior remains the same:
try to increase the tick time base;
try to completely reset (i.e. disable and re-enable) the timer inside the tick ISR;
try to create task delay through vTaskDelay, vTaskDelayUntil and xTimerCreate;
Moreover, I noticed if I disable all tasks (except for the idle one) the tick ISR (blue signal) is executed periodically every 1 ms as expected.
Regarding the weak attribute, i did not touch it. It was already like this from the original demo project i downloaded from Microchip GitHub. You suggest to change it?
Anyway, thank you so much! The position where I clear the flag was indeed the issue. Even though it is still not really clear to me why… I mean, the scheduler takes just something like few tens of microseconds to execute, so how can that cause the interrupt to be re-triggered if not immediately cleared?
This function is declared weak in the port layer to ensure that the application can override it. You should not declare it weak when overriding because when you have more than one weak functions (and no strong one), any one of those can be used. So, yes, remove weak.
@richard-damon has provided a possible explanation in the post I mentioned above, though I could not find it mentioned in dsPIC33 docs.
