dhemaius wrote on Wednesday, July 06, 2016:
FreeRTOS v8.2.3
System has been running for a while, then after a vTaskSwitchContext() call inside xPortPendSVHandler(), a hard fault occured when it tried to pop the core registers. Here is the list of values that did not make sense at that point :
pxCurrentTCB = 0x00000005 ( found out it came from corrupt pxReadyTasksLists[6] )
pxReadyTasksLists[6].uxNumberOfItems = 0xFFFFFFFF
pxReadyTasksLists[6].pxIndex = 0x2001ADA8
pxReadyTasksLists[6].pxIndex->pxNext = 0x2001ADA8
pxReadyTasksLists[6].pxIndex->pxPrevious = 0x2001ADA8
pxReadyTasksLists[6].pxIndex->pvOwner = 0x00000005 ( @ xDelayedTaskList1.uxNumberOfItems)
pxReadyTasksLists[6].pxIndex->pvContainer = 0x2001ADBC ( points on xDelayedTaskList1.xListEnd )
pxReadyTasksLists[6].xListEnd @ 0x2001ADA8
xDelayedTaskList1.uxNumberOfItems = 0x00000005
xDelayedTaskList1.pxIndex = 0x2001ADBC
xDelayedTaskList1.xListEnd @ 0x2001ADBC
uxTopReadyPriority = 81 ( configMAX_PRIORITIES = 7 !!! )
Any idea how such a corruption can happen?
Futhermore, sneeking around trying to find out how an empty list is still being used, I found something peculiar inside listGET_OWNER_OF_NEXT_ENTRY macro… Why reaffecting ( pxConstList )->pxIndex->pxNext to ( pxConstList )->pxIndex when it just found out that ( pxConstList )->pxIndex->pxNext is the end of the list marker, causing ( pxConstList )->pxIndex->pvOwner to be invalid?
#define listGET_OWNER_OF_NEXT_ENTRY( pxTCB, pxList ) \
List_t * const pxConstList = ( pxList ); \
/* Increment the index to the next item and return the item, ensuring */ \
/* we don't return the marker used at the end of the list. */ \
( pxConstList )->pxIndex = ( pxConstList )->pxIndex->pxNext; \
if( ( void * ) ( pxConstList )->pxIndex == ( void * ) &( ( pxConstList )->xListEnd ) ) \
( pxTCB ) = ( pxConstList )->pxIndex->pvOwner; \
