philpem wrote on Friday, January 27, 2017:
Here’s one picked up by IAR and confirmed by PC-LINT.
When FreeRTOS 9.0.0 is built with IAR EWARM, a warning is reported every time the taskCHECK_FOR_STACK_OVERFLOW macro is used. IAR doesn’t elaborate other than to say:
Warning[Pa082]: undefined behavior: the order of volatile accesses is undefined in this statement
Thankfully, PC-LINT also detects this error and can expand into the macro. The issue is the call to vApplicationStackOverflowHook on lines 97, 132 and 156 of StackMacros.h. The issue is that pxCurrentTCB is defined as volatile in tasks.c, but it is being used twice in the call of the stack overflow hook: once as the task handle (after being converted), and again to retrieve the task name.
While the stack checks are taking place during task switches and pxCurrentTCB shouldn’t be changing, the compiler isn’t to know this, so we get a warning that “pxCurrentTCB might change betweent the two reads and things might be inconsistent”.
Practically I can see two ways to resolve this –
- Take a copy of pxCurrentTCB as part of the stack overflow check and work on this instead of pxCurrentTCB. This already sort-of happens with pulStack, although I suspect this is more for reasons of brevity than an actual bug.
- Suppress the warning as part of the macro (this would be compiler specific).
What are everyone’s thoughts on this one? Seems like this is a fairly minor, easy to fix thing which wouldn’t cause an actual “bug”, just irritates developers with spurious compiler warnings.
Cheers,
Phil.
