i configure stack size of task=270.
i created a task which call many functions.
where all local variables of these function called by task will be stored?
is this memoey initialisation done by rtos or at compile time?
/* Allocate space for the stack used by the task being created.
The base of the stack memory stored in the TCB so the task can
be deleted later if required. */
pxNewTCB->pxStack = ( portSTACK_TYPE * ) pvPortMalloc( ( ( size_t )usStackDepth ) * sizeof( portSTACK_TYPE ) );
