rirititi wrote on Thursday, July 07, 2016:
A little question about the freeRTOS task scheduler:
Is the task scheduler called inside or just after the xQueueSend function or is the call done at the next system tick?
Thank you,
Thank you,
rtel wrote on Thursday, July 07, 2016:
Assuming you have configUSE_PREEMPTION set to 1, then a context switch
is performed immediately that a task with a priority above that of the
currently executing task becomes able to run. That means, if a lower
priority task unblocks a higher priority task by calling xQueueSend()
then the context switch will occur inside the xQueueSend() function.
Thank you for your fast answer.
