I have created a project with below tasks and tested the periodicity of each task which was as expected, but when I changed the stack size of the tasks as shown in second part I observed task is not executing with fixed period.
Can you please let me know the exact root cause of the behavior and its solution.
#if 0
/* all task executes with configured period*/
xTaskCreate(vEv_20ms1,"Test_20ms1", 1000, NULL, 23, NULL);
xTaskCreate(vEv_50ms1,"Test_50ms1", 100, NULL, 28, NULL);
xTaskCreate(vEv_50ms2,"Test_50ms2", 100, NULL, 25, NULL);
xTaskCreate(vEv_100ms1,"Test_100ms1", 100, NULL, 1, NULL);
xTaskCreate(vEv_100ms2,"Test_100ms2", 100, NULL, 1, NULL);
xTaskCreate(vEv_100ms3,"Test_100ms3", 100, NULL, 1, NULL);
xTaskCreate(vEv_100ms4,"Test_100ms4", 100, NULL, 1, NULL);
xTaskCreate(vEv_100ms5,"Test_100ms5", 100, NULL, 1, NULL);
xTaskCreate(vEv_100ms6,"Test_100ms6", 100, NULL, 1, NULL);
xTaskCreate(vEv_500ms1,"Test_500ms1", 100, NULL, 1, NULL);
xTaskCreate(vEv_500ms2,"Test_500ms2", 100, NULL, 1, NULL);
xTaskCreate(vEv_500ms3,"Test_500ms3", 100, NULL, 1, NULL);
xTaskCreate(vEv_500ms4,"Test_500ms4", 100, NULL, 1, NULL);
xTaskCreate(vEv_1000ms1,"Test_1000ms1", 100, NULL, 1, NULL);
xTaskCreate(vEv_1000ms2,"Test_1000ms2", 100, NULL, 1, NULL);
#else
/* Task lost its periodicity*/
xTaskCreate(vEv_20ms1,"Test_20ms1", 4000, NULL, 23, NULL);
xTaskCreate(vEv_50ms1,"Test_50ms1", 200, NULL, 27, NULL);
xTaskCreate(vEv_50ms2,"Test_50ms2", 500, NULL, 25, NULL);
xTaskCreate(vEv_100ms1,"Test_100ms1", 1000, NULL, 21, NULL);
xTaskCreate(vEv_100ms2,"Test_100ms2", 1000, NULL, 18, NULL);
xTaskCreate(vEv_100ms3,"Test_100ms3", 200, NULL, 17, NULL);
xTaskCreate(vEv_100ms4,"Test_100ms4", 4000, NULL, 16, NULL);
xTaskCreate(vEv_100ms5,"Test_100ms5", 500, NULL, 15, NULL);
xTaskCreate(vEv_100ms6,"Test_100ms6", 1000, NULL, 14, NULL);
xTaskCreate(vEv_500ms1,"Test_500ms1", 500, NULL, 12, NULL);
xTaskCreate(vEv_500ms2,"Test_500ms2", 400, NULL, 10, NULL);
xTaskCreate(vEv_500ms3,"Test_500ms3", 400, NULL, 8, NULL);
xTaskCreate(vEv_500ms4,"Test_500ms4", 1000, NULL, 6, NULL);
xTaskCreate(vEv_1000ms1,"Test_1000ms1", 1000, NULL, 4, NULL);
xTaskCreate(vEv_1000ms2,"Test_1000ms2", 500, NULL, 2, NULL);
FYI
FreeRTOSConfig.h is as below
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 1
#define configUSE_FPU 1
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ ( ( unsigned portLONG ) 80000000 ) /* Timer clock. */
#define configTICK_RATE_HZ ( ( TickType_t ) 1000 )
#define configMAX_PRIORITIES ( 30 )
#define configMINIMAL_STACK_SIZE ( ( unsigned portSHORT ) 128 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) 250000 )
#define configMAX_TASK_NAME_LEN ( 16 )
#define configGENERATE_RUN_TIME_STATS 1
#define configUSE_MALLOC_FAILED_HOOK 0
Thanks and advance,
Kishor
