I thought there was a recent post about tasks not starting in certain conditions - I saw the one regarding the queue fix - but has there been any other
problems in the recent past?
I looked through the forum back through July and didn’t see anything - and did a search but the search comes up with a lot of hits when you use the
word ‘task’.
I’m seeing a condition where vPortYield runs once, and that’s it. That particular task never runs again. I just see the
IDLE task running after that. I only have the IDLE task and a ‘test’ task running since I’m debugging some stack issues.
Is this using the MSP430? I know you are an expert on the RTOS so don’t want to ask obvious questions, but are you positive that the tick interrupt is running?
