I am using xTaskNotifyFromISR() in this ISR callback function:
void CHANGE_NOTICE_B_Handler (void)
CHANGE_NOTICE_B_InterruptHandler();
xTaskNotifyFromISR(xAPP_PRINTER_Tasks, 0x01, eSetBits);
and I have all the includes like this:
#include "configuration.h"
#include "definitions.h"
#include "app_printer.h"
#include "task.h"
and definition.h also has plenty of other includes as below:
#include <stdint.h>
#include <stddef.h>
#include <stdbool.h>
#include "peripheral/clk/plib_clk.h"
#include "peripheral/gpio/plib_gpio.h"
#include "peripheral/evic/plib_evic.h"
#include "driver/i2c/drv_i2c.h"
#include "system/time/sys_time.h"
#include "peripheral/i2c/master/plib_i2c2_master.h"
#include "peripheral/uart/plib_uart1.h"
#include "peripheral/tmr/plib_tmr2.h"
#include "system/console/sys_console.h"
#include "system/console/src/sys_console_uart_definitions.h"
#include "FreeRTOS.h"
#include "task.h"
#include "system/int/sys_int.h"
#include "osal/osal.h"
#include "system/debug/sys_debug.h"
#include "app_panel_io_exp.h"
#include "app_panel_exp_outputs.h"
#include "app_panel_exp_inputs.h"
#include "app_panel_exp_adc.h"
But I get the errors further below which does not make sense…
Any ideas/suggestions?
Thank you
../src/config/default/interrupts.c: In function 'CHANGE_NOTICE_B_Handler':
In file included from ../src/third_party/rtos/FreeRTOS/Source/include/queue.h:40:0,
from ../src/config/default/osal/osal_freertos.h:57,
from ../src/config/default/osal/osal_definitions.h:27,
from ../src/config/default/osal/osal.h:80,
from ../src/config/default/driver/i2c/src/drv_i2c_local.h:52,
from ../src/config/default/driver/i2c/drv_i2c.h:1394,
from ../src/config/default/definitions.h:54,
from ../src/config/default/interrupts.c:53:
../src/config/default/interrupts.c:102:17: error: 'xAPP_PRINTER_Tasks' undeclared (first use in this function)
xTaskNotify(xAPP_PRINTER_Tasks, 0x01, eSetBits);
../src/third_party/rtos/FreeRTOS/Source/include/task.h:1854:78: note: in definition of macro 'xTaskNotify'
#define xTaskNotify( xTaskToNotify, ulValue, eAction ) xTaskGenericNotify( ( xTaskToNotify ), ( ulValue ), ( eAction ), NULL )
../src/config/default/interrupts.c:102:17: note: each undeclared identifier is reported only once for each function it appears in
make[2]: *** [build/default/production/_ext/1171490990/interrupts.o] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
