I’m using an LPC824 part from NXP (ARM cortex-M0+).
I’ve a project with a single task, that’s blocked on a task notification. It has a timeout, which loops back to the beginning:
static void vDSBCommunicationTask (void *pvParameters) {
for(;;) {
uint32_t events;
if (xTaskNotifyWait(pdFALSE,UINT32_MAX,&events,pdMS_TO_TICKS(WWDT_DSB_FEED_TIMEOUT_MS))!=pdTRUE) {
Board_LED_Toggle();
continue;
//Do some real work.......
Normally this toggles the LED fine.
The interrupt notifies the task at various occasions, but one of these seems to suspend the task:
After this xTaskNotifyFromISR() is called, the LED stops blinking and the task is never unblocked.
When I stop the debugger, the vApplicationIdleHook() function is running fine, so the scheduler seems to be running.
If I request a context switch from within the dsb_allow_command() function, the task does get unblocked, but I don’t understand why it doesn’t work without that context switch request. I would expect that at the next systick event, the scheduler would notice that the task can be unblocked.
Thanks for your response.
I don’t think I fully understand your answer, as I seem unable to explain why the xTaskNotifyWait() will (regularly) timeout before the (I2C) interrupt has occured, and will no longer timeout after the (I2C) interrupt has occured.
The task has a priority of tskIDLE_PRIORITY + 1UL, so your point 1) tells me that after the (I2C) interrupt has occured (and the notification is posted) the tick interrupt should notice that the task (with a higher priority than the idle task) has become unblocked. At least it should keep noticing that it times out every now and then, just as it did before the (I2C) interrupt occurs.
Point (1) says a context switch will occur if the tick interrupt causes a task to unblock. In your case it was not the tick interrupt that caused a task to unblock.
So why not do that? You are setting the xHigherPriorityTaskWoken parameter to NULL - but it is intended that parameter is used to determine if a context switch is required or not.
