Hello, I have a problem about my FreeRTOS on STM32L476RG. I created two tasks, after I run this task, it is only run once, and then this task blocked. After I print from vTaskList I get return data like this,
Task State Prio Stack Num
IDLE X 0 8 3
base1 B 2 86 2
base2 B 1 102 1
Tmr Svc B 2 221 4
#define EXTERNAL_CLOCK
#include "main.h"
TaskHandle_t pMyTask ;
char ptrTaskList[250];
static void p1 (void *pvParameters ){
while(1){
if ( xSemaphoreTake( xSerialSemaphore, ( TickType_t ) 5 ) == pdTRUE )
SerialUSB.println("W");
xSemaphoreGive( xSerialSemaphore );
vTaskDelay(1);
static void p2 (void *pvParameters ){
while(1){
SerialUSB.println("S");
vTaskDelay(1);
void setup()
base_core::setup();
interface::setup();
// Now set up two Tasks to run independently.
if ( xSerialSemaphore == NULL ) // Check to confirm that the Serial Semaphore has not already been created.
xSerialSemaphore = xSemaphoreCreateMutex(); // Create a mutex semaphore we will use to manage the Serial Port
if ( ( xSerialSemaphore ) != NULL )
xSemaphoreGive( ( xSerialSemaphore ) ); // Make the Serial Port available for use, by "Giving" the Semaphore.
xTaskCreate(
p1
, (const portCHAR *)"base2" // A name just for humans
, 128 //configMINIMAL_STACK_SIZE // This stack size can be checked & adjusted by reading the Stack Highwater
, NULL
, 1 // Priority, with 3 (configMAX_PRIORITIES - 1) being the highest, and 0 being the lowest.
, NULL );
xTaskCreate(
p2
, (const portCHAR *)"base1" // A name just for humans
, NULL
, 2 // Priority, with 3 (configMAX_PRIORITIES - 1) being the highest, and 0 being the lowest.
, &pMyTask );
vTaskList(ptrTaskList);
Serial.println(F("Task State Prio Stack Num"));
Serial.print(ptrTaskList);
SerialUSB.flush();
// start scheduler
vTaskStartScheduler();
while(1);
void loop()
SerialUSB.flush();
delay(2000);
This is my code to test task. but this task only run once and then i check task state is blocked. Thank you
Everything looks as expected until the loop() function at the bottom. What is that?
Have you tried without the USB output - do the tasks continue to run then?
Do you have configCHECK_FOR_STACK_OVERFLOW set to 2, as recommended during development and debug here: https://www.freertos.org/FAQHelp.html
