System gets stuck in hardfault handler when 64Kbytes data is transmitted
i am able to transmit the complete data but sometimes system gets stuck in Hard Fault Handler during start, i think there is some issue in “pxPortInitialiseStack() at port.c:214 0x8011334”-
Hard Fault Stack-
cam_bsnet Debug [STM32 C/C++ Application]
cam_bsnet.elf [cores: 0]
Thread #1 [main] 1 [core: 0] (Suspended : Signal : SIGTRAP:Trace/breakpoint trap)
HardFault_Handler() at stm32h7xx_it.c:112 0x8001e2c
() at 0xfffffffd
ethernet_input() at ethernet.c:113 0x8021bb4
tcpip_thread_handle_msg() at tcpip.c:174 0x80159d6
tcpip_thread() at tcpip.c:148 0x801598a
arm-none-eabi-gdb (13.2.90.20230627)
ST-LINK (ST-LINK GDB server)
Need help resolving this.
No, the issue is likely in your ethernet_input() function. Check the implementation of this function to see if this might be causing some memory corruption.
I agree with @aggarg here. Is your ethernet function somehow relying upon the stack for transmission? Or does the function require more than the configured stack size?
