cwallen-89 wrote on Thursday, September 21, 2017:
So this is my current attempt at implementing the above code as two separate tasks:
spiDAT1_t dataconfig1_t;
/* Define Task Handles */
xTaskHandle xTask1Handle;
xTaskHandle xTask2Handle;
uint16 TX_Data_Master[16] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10 };
uint16 RX_Data_Master[16] = { 0 };
uint16 TX_Data_Slave[16] = { 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1E, 0x1F, 0x20 };
uint16 RX_Data_Slave[16] = { 0 };
/* Task1 */
void vTask1(void *pvParameters)
dataconfig1_t.CS_HOLD = FALSE;
dataconfig1_t.WDEL = TRUE;
dataconfig1_t.DFSEL = SPI_FMT_0;
dataconfig1_t.CSNR = 0xF7;
for(;;)
/* Initiate SPI2 Transmit and Receive through Interrupt Mode */
spiSendAndGetData(spiREG2, &dataconfig1_t, 16, TX_Data_Slave, RX_Data_Slave);
/* Task2 */
void vTask2(void *pvParameters)
for(;;)
/* Initiate SPI1 Transmit and Receive through Polling Mode */
spiTransmitAndReceiveData(spiREG1, &dataconfig1_t, 16, TX_Data_Master, RX_Data_Master);
/* USER CODE END */
/** @fn void main(void)
@brief Application main function
@note This function is empty by default.
- This function is called after startup.
- The user can use this function to implement the application.
/* USER CODE BEGIN (2) /
/ USER CODE END */
void main(void)
/* USER CODE BEGIN (3) */
spiInit();
/* Create Task 1 */
if (xTaskCreate(vTask1,"Task1", configMINIMAL_STACK_SIZE, NULL, 1, &xTask1Handle) != pdTRUE)
/* Task could not be created */
while(1);
/* Create Task 2 */
if (xTaskCreate(vTask2,"Task2", configMINIMAL_STACK_SIZE, NULL, 1, &xTask2Handle) != pdTRUE)
while(1);
/* Start Scheduler */
vTaskStartScheduler();
/* Run forever */
while(1);
/* USER CODE END */
Initially, I only had one task which initiated both spi registers. Here I am trying to create two tasks which each initiate a different SPI port. I assumed that they would simply communicate properly with the same setup. However, this is not the case. When I run the code, RX_Data_Slave ends up with a scrambled assortment of the values from TX_Data_Master; some values are missing and TX_Data_Master is overwritten by different values; and RX_Data_Master sometimes gets nothing and sometimes gets something similar to RX_Data_Slave. I’m thinking I have to have the two tasks communicate with each other in some way in order to prevent this from happening. I’m just not entirely sure how. I attached a snip of an example of what happens with the buffer data (it’s not consistent as the values change almost every time I run the program). The formatting is a bit off so you may have to just download it in order to view it if you need to.
