wella wrote on Friday, January 29, 2010:
below is a simple inter-task synchronization barrier implementation. Of course, because this is not a part of kernel, there are many assumptions of using it. The master must at first create barrier(you cannot re-enter if was not created first). After that, tasks can wait on this barrier with a timeout. If timeout expired, all waiting tasks are waken with error. The return value of function barrierState determines if there are still tasks which did not reach the barrier.
Martin
typedef struct
unsigned portSHORT counter;
unsigned portSHORT max;
xQueueHandle xQueue;
} barrier;
#define BARRIER_SUCCESS pdTRUE
#define BARRIER_FAILED pdFAIL
unsigned portBASE_TYPE barrierTake(barrier * b, portTickType xTicksToWait)
unsigned portBASE_TYPE mess = BARRIER_SUCCESS;
// Enter to shared memory region
portENTER_CRITICAL();
// Increment common counter
b->counter++;
// Exit critical section
portEXIT_CRITICAL();
// Barrier reached?
if(b->counter < b->max)
// Not all tasks finished yet.
// Wait on the other tasks with timeout. Due to "peek" message will remain
// in message queue.
if(pdTRUE != xQueuePeek( b->xQueue, &( mess ), xTicksToWait))
// Timeout. Inform other tasks about missed timeout.
mess = BARRIER_FAILED;
xQueueSend( b->xQueue, ( void * ) &mess, ( portTickType ) 0 );
// If there is stored a message do not send.
if(uxQueueMessagesWaiting( b->xQueue) > 0)
// Receive message(peek).
xQueuePeek( b->xQueue, &( mess ), ( portTickType )0);
// All tasks finished.
// Inform other tasks.
// Return status.
return mess;
void barrierCreate(barrier * b, unsigned portSHORT max)
// Used only as a dummy place(/dev/null) for flushing queue.
unsigned portBASE_TYPE mess;
// Set number of tasks to synchronize.
b->max = max;
// Reset counter.
b->counter = 0;
// Create or empty a message queue.
if(NULL == b->xQueue)
// Queue was not created, create....
b->xQueue= xQueueCreate( 1, sizeof( unsigned long ) );
// Queue was created, flush....
while(pdTRUE == xQueueReceive( b->xQueue, &( mess ), ( portTickType )0))
// NOP();
portBASE_TYPE barrierState(barrier * b)
// How many task was not entered into barrier?
// -1 means more than max defined tasks.
return (b->max - b->counter);
barrier bar;
void start(void * par)
barrierCreate(&bar, 4);
printf("start:%d\n",barrierTake(&bar,100));
vTaskDelay(100);
printf("start: state %i\n",barrierState(&bar));
vTaskSuspend(NULL);
void A(void * par)
printf("A:%d\n",barrierTake(&bar,portMAX_DELAY));
printf("A1:%d\n",barrierTake(&bar,portMAX_DELAY));
vTaskSuspend(NULL);
void B(void * par)
vTaskDelay(1);
printf("B:%d\n",barrierTake(&bar,portMAX_DELAY));
vTaskSuspend(NULL);
void C(void * par)
printf("C:%d\n",barrierTake(&bar,portMAX_DELAY));
vTaskSuspend(NULL);
int main()
xTaskCreate( start, "start", 100,NULL,4, NULL );
xTaskCreate( A, "A", 100,NULL, 3, NULL );
xTaskCreate( B, "B,", 100,NULL, 2, NULL );
xTaskCreate( C, "C", 100,NULL, 1, NULL );
/* Start the scheduler, this function should not return as it causes the execution
context to change from main() to one of the created tasks. */
vTaskStartScheduler();
/* Should never get here! */
return 0;
