I use CORTEX M4 -(SAM4LC8) with FreeRtos Kernel, I would like to know how the switching of the tasks works. Is there any timer ? which timer? is it RTC?. Because on AVR I used the FreeRtos, where the tasks were switched by timer. I found function vPortSetupTimerInterrupt, but there is nothing like init of any timer, which could swith the tasks.
Assuming you are using a standard rather than tickless port (as there is a tickless implementation for the SAM4L) then it is using the SysTick timer, which is build into the Cortex-M core itself rather than being a separate peripheral.
OK, and does the SysTick timer tick in sleep mode? in datasheet is not any information about SysTick timer, there is only information about RCSYS - but suppose, that is different timer?!
That would depend on the sleep mode.
You need to be looking in the ARM Cortex-M datasheet - there is a lot of
information. Simply Googling “Cortex Systick timer” will overwhelm you
with information.
Quite definitely a different timer. Presumably that is a peripheral
timer that is specific to the device you are using, rather than part of
the Cortex core.
