The definition for portYIELD() for the RX600 port in V7.0.2, (FreeRTOS/Source/portable/GCC/RX600/portmacro.h) looks like this:
/* The location of the software interrupt register. Software interrupts use
vector 27. */
#define portITU_SWINTR ( ( unsigned char * ) 0x000872E0 )
#define portYIELD() *portITU_SWINTR = 0x01; portNOP(); portNOP(); portNOP(); portNOP(); portNOP()
This raises several questions:
First, why not use a trap instruction (e.g: “INT #27”) for portYIELD() (as was done for the H8S port for example)?
Second, what bug or (apparently undocumented) feature requires the use of no less than 5 NOPs after setting the SWINTR register?
Lastly, shouldn’t it be enclosed in a do{}while(0) block? Or better yet, shouldn’t it be a static inline function? As is, an otherwise perfectly reasonable code snipit such as
The asynchronous software interrupt is a far more powerful method, and included in the core for this purpose (as it is in the Cortex-M). I believe it was an addition that came to the architecture after the RX610 devices.
Using a synchronous trap has two disadvantages in this case. First, supporting interrupt nesting is much more complex and requires much more code. Second, as a result of the first, interrupt response times are adversely effected.
I would have to check the data sheets to answer that one. It might be preventing execution of instructions in branch delay slots, or pipelines. I use a *lot* of different cores and cannot recall offhand. It might be that the NOPs are no longer needed even.
I take the point about the hanging else. My coding standard will not permit an if without an explicit {} block, but granted the code provided should allow for use in everybody’s applications. The while(0) solution is a non starter for this proect. First, it breaches nearly all formal coding standards. Second it will cause “condition is always false” warnings from the compiler in a lot of cases (depending on the warning level - I tend to compile with very pedantic warnings).
