I am working FreeRTOS in CortexM3 platform. As we know, we need define the following code in startup.s to make sure FREERTOS work.
IF FreeRTOS = {TRUE}
DCD vPortSVCHandler ; FreeRTOS SVC handler
ELSE
DCD SVC_Handler ; SVCall Handler
ENDIF
DCD DebugMon_Handler ; Debug Monitor Handler
DCD 0 ; Reserved
DCD xPortPendSVHandler ; FreeRTOS PendSV Handler
ELSE
DCD PendSV_Handler ; PendSV Handler
ENDIF
But I found that USB otg code will call SVC_Handler and PendSV_Handler when communication with mass storage device.
So, it seems not possible that merge USBOTG function in FreeRTOS environment …
I don’t know where your USBOTG software came from, not from me that’s for sure. If it is using such a major core resource such as SVC then I would imagine it comes with instructions on how to integrate it into you code.
FreeRTOS only uses an SVC 0 call. It uses it once only, to start the scheduler, and then never uses it again. You therefore have three choices:
1) Move the vector table into RAM, then when the kernel has started, rewrite the SVC handler entry to use the USB OTG code.
2) Have two copies of the vector table, one in flash with the FreeRTOS handler as per normal, and one in RAM with the USB handler. Then, when the scheduler has started, remap the vector table using the vector base address register.
3) Update the FreeRTOS handler so it checks the SVC call parameter. Currently it assumes only one thing is using the SVC call, so it does not bother to check it and just assumes it is 0.
first, thanks for your adivise…the usb otg code from ST… I use ST cortex M3 platform…its OTG code refers to SVC handler. ST guys develop a new file system library to operate USB file operation…I think method3 is ok for me .do you help support it ?
regards
I checked FreeRTOS code and find that it call " svc 0" to trigger svc handler…so it is possible to get the parameter of svc handler. would you help to get the parameter in svc_handler function … if this, I could dispath them to different svcaller …
thank you
I was about to post a question related to the usage of SVC in FreeRTOS, and I found this post from 2011. Now in 2024, is it still valid that FreeRTOS uses SVC 0 call only once to start the first task? I already rewrote the SVC handler entry but I still have this question if in the future I will find some strange behaviour.
I forgot to share that detail, I’m actually interested in the Cortex-M7 port (ARM_CM7). At first sight I can only identify one SVC call in the prvPortStartFirstTask function. In this port is this the only time it is ever called?
