Support for FPU context switch in RISC-V
Hello, I noticed that the RISC-V port does not support (re-)storing the floating point context as part of the context switch process.
I would like to provide that support for FPU. To test it I would also create a Demo port based on QEMU (similar to RISC-V_RV32_QEMU_VIRT_GCC) but that supports:
  1. xlen 64 bits
  2. f extension (to have the FPU)
  3. (In a subsequent PR) Vector support
Does it make sense? Should I create the PRs (in FreeRTOS and FreeRTOS-Kernel) directly or what should I do first?
Thanks!
@cubidesj
Thanks for your interest in contributing to the FreeRTOS kernel.
Does it make sense?
Yes, it looks good to me.
You can work on the forked versions of FreeRTOS (for the new demo) and FreeRTOS-Kernel (for supporting FPU in the port) repos and create the PRs together to each of their official repos once they’re ready, so that test/review processes can be performed easily.
Do we really need to create a new demo? Can the existing one not be used to show FPU also (likely by adding register tests that store and verify floating point registers)?
I was thinking of having one that is close to RVA23 (http://github.com/riscv/riscv-profiles/blob/main/src/rva23-profile.adoc). Which would be 64-bit (which I did not see on QEMU) and include both FPU and Vector unit (I would also add support for vectors in a later PR).
Those characteristics are different enough from each of the current demos that I thought about creating a new one but I agree that the difference in code itself is small. So I see a few possibilities:
  1. Create a new Demo (as I was doing)
  2. Update RISC-V_RV32_QEMU_VIRT_GCC to support FPU (and later VPU) but we still wouldn’t have a 64-bit QEMU version
  3. Update RISC-V_RV32_QEMU_VIRT_GCC to support FPU (and later VPU) and 64 bits (which would imply a rename because it no longer would be RV32)
  4. Something else that you propose
Please let me know what you think
I am indeed updating the RegTest (under FreeRTOS/Demo/RISC-V_RV32_QEMU_VIRT_GCC/build/gcc/RegTest.S) to include the FPU registers
I like this one except the renaming part as it may break some CIs. Are you thinking of a build time option to pick 32 vs 64 bit? If yes, we can keep 32 but default.
Yes, a compile time option. I’ll begin working into this, then.
Well, I do think that leaving the “RV32” in the name would be misleading but I have no idea if I can do anything for the potentially broken CIs.
Agree that it is a bit misleading. Let’s work on the PR and we’ll see if anything could be done in this regard.
I created the following two PR. I also noticed that CI was complaining on the FreeRTOS one so I added a couple of extre comments to solve those issues.
  • FreeRTOS:#1329 and
  • FreeRTOS-Kernel:#1250
Thank you for creating the PRs. We will review them and get back to you.
