pixt wrote on Monday, March 06, 2017:
I am using a Xilinx Zynq-7000 (ARM Cortex A9) with FreeRTOS. I recently had the problem that my interrupt service routine wrote into memory regions it was not supposed to due to a stack overflow. The problem was not solved by only increasing the IRQ stack size in the linker script. I found out that the ISR was using the supervisor stack. After increasing the size of the supervisor stack the stack overflow disappeared. Can you explain to me why the ISR uses the supervisor stack and why it was neccessary to increase the size of the supervisor stack?
Thank you.
Best regards,
pixt
