nobody wrote on Tuesday, July 18, 2006:
I studied the context save and restore routines and noticed that 1 byte too much is saved for the MATH_DATA and .tmpdata sections. Also the stack initialisation is 1 byte too long.
If portCOMPILER_MANAGED_MEMORY_SIZE is 0x13 as in the default/demo, 19 bytes should be saved.
(I assume MATH_DATA plus .tmpdata sections are 19 bytes long)
The initialisation loop runs 20 times however (from 0 to (and including) 19).
The save_context routine uses
MOVFF POSTINC0, PREINC1
to save the first 19 bytes (at adresses 0 to 18), and then executes an additional
MOVFF INDF0, PREINC1
to store adress 19 without incrementing the FSR0 register.
This is potentially harmful because the byte at adress 19 could be a global variable which is supposed to be changed by an other task, but restoring the old task context overwrites the new value.
Fix: if MATH_DATA plus tmpdata sections are 19 bytes long, documentation should state clearly that 18 MOVFF POSTINC0,PREINC1 and
1 MOVFF INDF0,PREINC1 instructions are required to save the sections.
The stack initialisation ‘for loop’ should also be changed to loop one time less or documentation should state that portCOMPILER_MANAGED_MEMORY_SIZE should be initialised 1 less.
Paul
