I set-up a project based on the one generated by CubeMX using FreeRTOS (CMSISv2) and lwIP for STM32F4. Everything works fine as long as I send one tcp/ip packet after each other (like in case of ping) .
But if I put more stress on the device I always get stuck in the eth receive callback that tries to release a semaphore the receive task is waiting for. The queue length is ‘1’ as expected, but somehow there is no owner to the entry… Does anybody have an idea how this can happen?
I’m using V10.3.1 of FreeRTOS and v2.1.2 of lwIP.
any ideas or comments would very well be appreciated.
pxUnblockedTCB = listGET_OWNER_OF_HEAD_ENTRY( pxEventList ); /*lint !e9079 void * is used as this macro is used with timers and co-routines too. Alignment is known to be fine as the type of the pointer stored and retrieved is the same. */
configASSERT( pxUnblockedTCB );
ok, I discovered a wrong irq priority in the lwip thread config. Now at least I pass the assert but never the less I have somehow corrupted memory since I get stuck within the call of uxListRemove. The address that returned by listGET_OWNER_OF_HEAD_ENTRY is strange because it points somewhere into the ROM and so the containing information is also not right.
