rlaa wrote on Thursday, October 24, 2019:
I am experimenting with stream buffers, in kernel version 10.2.1.
It appears there is an inconsistency in the documentation for the xStreamBufferCreateStatic() call.
https://www.freertos.org/xStreamBufferCreateStatic.html
The pucStreamBufferStorageArea description specifies that buffer must be at least xBufferSizeBytes + 1 big. The xBufferSizeBytes description is “The size, in bytes, of the buffer pointed to by the pucStreamBufferStorageArea parameter.”
Document correction needed?
Thanks,
-Rob
