I’m an engineering student and very new to FreeRTOS and embedded programming as a whole, so please forgive my ignorance.
I’m making a digital alarm clock project with RTC and FreeRTOS on an STM32F401RE NUCLEO board. I am also using an older version of SEGGER SystemView.
This is the strangest bug I’ve ever experienced. Essentially, I’m trying to print a string to an LCD. Every time I call the lcdSendString() function, it prints some string found elsewhere in the build. I’ve even hard coded “hello world” in the print task handler, but the bug persists.
rtcUpdateTimerCallback and the print task are synchronized with a queue, but as I’ve implemented it for now, the queue does nothing more than that.
There is a possibility that my LCD driver is responsible as I made it myself, but from what I’ve seen it prints strings correctly.
printTaskHandler:
void printTaskHandler(void *parameters){
uint32_t *str;
while(1){
xTimerStop(rtcUpdateTimerHandle, portMAX_DELAY);
xQueueReceive(printQueueHandle, &str, portMAX_DELAY);
lcdClear();
lcdMoveCursor(0, 0);
lcdSendString("hello world");
xTimerStart(rtcUpdateTimerHandle, portMAX_DELAY);
rtcUpdateTimerCallback:
void rtcUpdateTimerCallback(TimerHandle_t xTimer){
static int counter = 0;
static const char* msg1 = "Hello";
static const char* msg2 = "World";
while (1){
if (counter % 2 == 0){
xQueueSend(printQueueHandle, (void*) &msg1, portMAX_DELAY);
else {
xQueueSend(printQueueHandle, (void*) &msg2, portMAX_DELAY);
counter++;
LCD Driver:
lcdSendString:
void lcdSendString(char *str){
for(uint8_t i = 0; i < strlen(str) || i < 100; i++){
lcdSendData(str[i]);
lcdSendData:
static void lcdSendData(char data){
//send 4 MSBs
lcdSend( (data >> 4) & 0x0f, RS_DATA );
//send 4 LSBs
lcdSend( (data >> 0) & 0x0f, RS_DATA );
Example of Corrupted String:
