STR710 interrupt and freeRTOS
frankandersen wrote on Friday, September 21, 2007:
Does the port for the STR71x support nested interrupts?
Meaing while executing eg. the TimerTickInterrupt, does it then accept interrupts of a higher priority?
Or is the higher priority interrupt blocked until the end of TimerTickInterrupt?
Best regards,
Frank Andersen
davedoors wrote on Friday, September 21, 2007:
Here is an FAQ on this http://www.freertos.org/FAQISR.html#Nest
Consider using the FIQ before changing to use nested interrupts.
frankandersen wrote on Monday, September 24, 2007:
Hi Dave,
Unfortuneatly the STR710 is not very flexible with use of FIQ, only the watchdog and timer0 can be asigned to FIQ.
When will the configKERNEL_INTERRUPT_PRIORITY be implemented in the ARM7 ports?
Best regards,
Frank Andersen
