I am trying to enter sleepmode in freertos, but for some reason the system does not enter it.
GLOBAL void SleepMode_Activate(void) {
unsigned int sleep;
flag = 1;
/*Disable display task if not already disabled*/
if (mt_TaskStatus(_TN_ANZ) != _SLEEPING) {
mt_Terminate(_TN_ANZ); //Disabled Display
/*Turn off lcd and other stuff*/
vw_SlowHwAus();
/*disables COMs if necessary*/
/*Enable there alternate wakeup pins of COM*/
vw_ComBeenden();
slowspeed_timers = 1;
/*Enable interrupt on buttons, before they were working in timer*/
tas_Starten();
mt_TimerDis();
osThreadTerminate(Tasks_ID[_TN_KZR]);
SleepMode_DisableUart();
hw_SetSpeedSlow();
HAL_SuspendTick();
SysTick->CTRL &= ~SysTick_CTRL_TICKINT_Msk;
HAL_PWR_EnterSLEEPMode(PWR_LOWPOWERREGULATOR_ON, PWR_SLEEPENTRY_WFI);
//************** Slow Section Start
do {
hw_Wdr();
// bib_Nop025us();
// because of Instruction Que
if (bSekNeu) // meanwhile a change of seconds takes place ?
bSekNeu = 0;
vw_TestNetzSlow(); // Check supply
} while (bBedienReq == 0 && bUmwReq == 0// bMinNew == 0 is included in bUmwReq
&& SioReq == 0 && MeldReq == 0);// as long as no key, no min, no SIO, no message
//************** Slow End section
//__HAL_FLASH_SLEEP_POWERDOWN_DISABLE();
/* System is Low Power Run mode when exiting Low Power Sleep mode,
disable low power run mode and reset the clock to initialization configuration */
HAL_PWREx_DisableLowPowerRunMode();
hw_SetSpeedFast();
/* Resume Tick interrupt if disabled prior to Low Power Sleep mode entry */
HAL_ResumeTick();
SysTick->CTRL |= SysTick_CTRL_TICKINT_Msk;
slowspeed_timers = 0;
mt_TimerEn();
uhr_LiesRtc(); // Complete time
vw_ComReact(); // V2.0
//osKernelRestoreLock(lock)
I also disabled systick and my base timer. I made sure no interrupts are being generated, but still I cant go into sleepmode. I think this is some kind of a bug. I am not using tickless idle right now for some reasons.
So, I tested it.
before initializing the kernel the system is stopping at sleepmode.
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_CRC_Init();
MX_TIM5_Init();
MX_TIM1_Init();
MX_TIM17_Init();
MX_USART1_UART_Init();
MX_SPI1_Init();
MX_ADC1_Init();
MX_USART3_UART_Init();
MX_TIM6_Init();
MX_USART2_UART_Init();
MX_FMC_Init();
MX_UART4_Init();
MX_IWDG_Init();
MX_UART5_Init();
MX_TIM2_Init();
MX_TIM7_Init();
MX_TIM4_Init();
MX_RTC_Init();
/* USER CODE BEGIN 2 */
// crc_CCITT_Init();
hw_SetSpeedSlow();
HAL_SuspendTick();
// sleep = osKernelSuspend();
/* USER CODE END 2 */
/* Init scheduler */
osKernelInitialize();
/* USER CODE BEGIN RTOS_MUTEX */
/* add mutexes, ... */
/* USER CODE END RTOS_MUTEX */
/* USER CODE BEGIN RTOS_SEMAPHORES */
/* add semaphores, ... */
/* USER CODE END RTOS_SEMAPHORES */
/* USER CODE BEGIN RTOS_TIMERS */
/* start timers, add new ones, ... */
/* USER CODE END RTOS_TIMERS */
/* USER CODE BEGIN RTOS_QUEUES */
/* add queues, ... */
//DO NOT disable this default task
/* USER CODE END RTOS_QUEUES */
/* Create the thread(s) */
/* creation of defaultTask */
// defaultTaskHandle = osThreadNew(StartDefaultTask, NULL, &defaultTask_attributes);
/* USER CODE BEGIN RTOS_THREADS */
// HAL_UART_DeInit(&huart1);
// HAL_UART_DeInit(&huart2);
// HAL_UART_DeInit(&huart3);
vw_Main();
/* add threads, ... */
/* USER CODE END RTOS_THREADS */
/* USER CODE BEGIN RTOS_EVENTS */
/* add events, ... */
/* USER CODE END RTOS_EVENTS */
/* Start scheduler */
osKernelStart();
/* We should never get here as control is now taken by the scheduler */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1) {
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
