So, in my previous post, I mentioned that I was trying to go into sleep mode without tickless idle mode and was not successfull, but after testing I found the issue, it was one of the interrupts was waking up the cpu, after disabling it, I was able to access sleepmode.
Now I am trying to access sleepmode in tickless idle mode, but same problem persist here. The system immediatly comes out of the sleepmode even after making sure interrupts are disabled.
So I tried example project from st for freertos lowpower mode and it also does not stays inside sleepmode. Then I created a barebone project with nothing just freertos enabled with tickless idle and I was not able to access the sleepmode.
this st example I used
STM32CubeL4/tree/master/Projects/NUCLEO-L496ZG/Applications/FreeRTOS/FreeRTOS_LowPower
no success.
