I’ve set up a project with LL library using TIM7 as the clock source for FreeRTOS, where FreeRTOS is configured outside CubeMX. Running on STM32H743ZI2 Nucleo board. I’m doing this because I need highly accurate timing with FreeRTOS.
It is a simple blink program, but I am not able to decipher if it is a problem with interrupt priority for TIMER7 (which needs to be high since it is the clock source of FreeRTOS), a stack issue, or something else entirely. With priority of 0 for Timer7IRQ, I get a tick hook message, otherwise with priority of 5 or numerical higher number till 15, there is no breakpoint hit in the TIM7_IRQHandler.
It was completely set up by me, but it is stuck very close to working condition. Please help.
main.c
int main(void)
/* USER CODE BEGIN 1 */
// TaskHandle_t xHandleLED1,
/* USER CODE END 1 */
/* MPU Configuration--------------------------------------------------------*/
MPU_Config();
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
SCB_EnableICache();
SCB_EnableDCache();
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_UART4_Init();
MX_TIM7_Init();
/* USER CODE BEGIN 2 */
LL_TIM_EnableCounter(TIM7); // Start counting
/* USER CODE END 2 */
/* Initialize leds */
BSP_LED_Init(LED_GREEN);
BSP_LED_Init(LED_YELLOW);
BSP_LED_Init(LED_RED);
/* Infinite loop */
/* USER CODE BEGIN WHILE */
TaskHandle_t xTaskHandle1;
TaskHandle_t xTaskHandle2;
xTaskCreate(blinkLeds,"2LED", 256, NULL, 1, &xTaskHandle1);
xTaskCreate(blinkLED,"led_1", 256, NULL, 1, &xTaskHandle2);
markTaskScheduleRunning();
vTaskStartScheduler();
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
static void MX_TIM7_Init(void)
/* USER CODE BEGIN TIM7_Init 0 */
/* USER CODE END TIM7_Init 0 */
LL_TIM_InitTypeDef TIM_InitStruct = {0};
/* Peripheral clock enable */
LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_TIM7);
/* TIM7 interrupt Init */
NVIC_SetPriority(TIM7_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
// NVIC_SetPriority(TIM7_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 15, 0));
NVIC_EnableIRQ(TIM7_IRQn);
/* USER CODE BEGIN TIM7_Init 1 */
// NVIC_DisableIRQ(TIM7_IRQn);
LL_TIM_EnableIT_UPDATE(TIM7);
/* USER CODE END TIM7_Init 1 */
TIM_InitStruct.Prescaler = 63;
TIM_InitStruct.CounterMode = LL_TIM_COUNTERMODE_UP;
TIM_InitStruct.Autoreload = 999;
LL_TIM_Init(TIM7, &TIM_InitStruct);
LL_TIM_EnableARRPreload(TIM7);
LL_TIM_SetTriggerOutput(TIM7, LL_TIM_TRGO_UPDATE);
LL_TIM_DisableMasterSlaveMode(TIM7);
/* USER CODE BEGIN TIM7_Init 2 */
// LL_TIM_DisableCounter(TIM7);
/* USER CODE END TIM7_Init 2 */
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
void write_data_to_uart(uint8_t* data, uint8_t length){
if(data == NULL) return;
while(length > 0){
while(!LL_USART_IsActiveFlag_TC(UART4));
LL_USART_TransmitData8(UART4, (uint8_t)(*data));
length--;
data++;
static void blinkLeds(void *argument){
// write_data_to_uart((uint8_t*)(&stringForMessage1), sizeof(stringForMessage1));
char stringfortask1[] = "task 1 running correctly";
while(1){
write_data_to_uart((uint8_t*)(&stringfortask1), sizeof(stringfortask1));
LL_GPIO_TogglePin(GPIOB, LL_GPIO_PIN_14| LL_GPIO_PIN_0);
vTaskDelay(pdMS_TO_TICKS(800));
static void blinkLED(void *argument){
char stringfortask1[] = "running correctly the second task";
while(1){
LL_GPIO_TogglePin(GPIOE, LL_GPIO_PIN_1);
vTaskDelay(pdMS_TO_TICKS(500));
void vApplicationStackOverflowHook(TaskHandle_t xTask, char *pcTaskName)
char stringForMallocError[] = "Error for Stack overflow ";
while (1){
write_data_to_uart((uint8_t*)(&stringForMallocError), sizeof(stringForMallocError));
vTaskDelay(pdMS_TO_TICKS(1000));
void vApplicationMallocFailedHook(void)
char stringForMallocError[] = "Error for malloc";
while (1){
void vApplicationIdleHook(void)
char stringForIdle[] = "Idle task is running";
if(counter %1000 == 0){
counter++;
write_data_to_uart((uint8_t*)(&stringForIdle), sizeof(stringForIdle));
void vApplicationTickHook(void)
char stringForIdle[] = "Tick hook task is running";
vTaskDelay(pdMS_TO_TICKS(3000));
void vApplicationGetIdleTaskMemory( StaticTask_t **ppxIdleTaskTCBBuffer, StackType_t **ppxIdleTaskStackBuffer, uint32_t *pulIdleTaskStackSize )
static StaticTask_t xIdleTaskTCBBuffer;
static StackType_t uxIdleTaskStack[ configMINIMAL_STACK_SIZE ];
// Pass the buffers to FreeRTOS
*ppxIdleTaskTCBBuffer = &xIdleTaskTCBBuffer;
*ppxIdleTaskStackBuffer = uxIdleTaskStack;
*pulIdleTaskStackSize = configMINIMAL_STACK_SIZE;
void vApplicationGetTimerTaskMemory( StaticTask_t **ppxTimerTaskTCBBuffer, StackType_t **ppxTimerTaskStackBuffer, uint32_t *pulTimerTaskStackSize )
// The buffer that will hold the task's TCB (Task Control Block)
static StaticTask_t xTimerTaskTCBBuffer;
// The buffer that will hold the task's stack
static StackType_t uxTimerTaskStack[ configTIMER_TASK_STACK_DEPTH ];
*ppxTimerTaskTCBBuffer = &xTimerTaskTCBBuffer;
*ppxTimerTaskStackBuffer = uxTimerTaskStack;
*pulTimerTaskStackSize = configTIMER_TASK_STACK_DEPTH;
FreeRTOSConfig.h
/* Ensure stdint is only used by the compiler, and not the assembler. */
#if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
#include <stdint.h>
extern uint32_t SystemCoreClock;
// CRITICAL FIXES:
#define configUSE_IDLE_HOOK 1 // CHANGED: Enable for debugging
#define configUSE_TICK_HOOK 1 // CHANGED: Enable for debugging
#define configCPU_CLOCK_HZ ( SystemCoreClock )
#define configTICK_RATE_HZ ( ( TickType_t ) 1000 )
#define configMAX_PRIORITIES ( 7 )
#define configMINIMAL_STACK_SIZE ( ( uint16_t ) 256 ) // CHANGED: Reduced from 512
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 64 * 1024 ) )
#define configMAX_TASK_NAME_LEN ( 16 )
#define configUSE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 8
#define configCHECK_FOR_STACK_OVERFLOW 2 // CHANGED: Enable stack overflow detection
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_MALLOC_FAILED_HOOK 1 // CHANGED: Enable for debugging
#define configUSE_APPLICATION_TASK_TAG 0
#define configUSE_COUNTING_SEMAPHORES 1
#define configGENERATE_RUN_TIME_STATS 0
// CRITICAL FIX: Enable dynamic allocation
#define configSUPPORT_STATIC_ALLOCATION 0 // CHANGED: Disable static
#define configSUPPORT_DYNAMIC_ALLOCATION 1 // ADDED: Enable dynamic allocation
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
/* Software timer definitions. */
#define configUSE_TIMERS 0
#define configTIMER_TASK_PRIORITY ( 2 )
#define configTIMER_QUEUE_LENGTH 10
#define configTIMER_TASK_STACK_DEPTH ( configMINIMAL_STACK_SIZE * 2 )
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 1
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xQueueGetMutexHolder 1
#define INCLUDE_xTaskGetSchedulerState 1
#define INCLUDE_eTaskGetState 1
#define INCLUDE_uxTaskGetStackHighWaterMark 1 // ADDED: For stack debugging
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
/* __NVIC_PRIO_BITS will be specified when CMSIS is being used. */
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 4 /* 15 priority levels */
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0xf
routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt priorities used by the kernel port layer itself. These are generic
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
#define configASSERT( x ) if( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
/* CRITICAL FIX: These MUST be commented out when using custom tick source (TIM7)
Uncomment ONLY if using SysTick for FreeRTOS tick */
// #define vPortSVCHandler SVC_Handler
// #define xPortPendSVHandler PendSV_Handler
// #define xPortSysTickHandler SysTick_Handler
/* ADDED: Memory management scheme - use heap_4.c */
#define configUSE_NEWLIB_REENTRANT 0
stm32h7xx_it.c:
void TIM7_IRQHandler(void)
if (LL_TIM_IsActiveFlag_UPDATE(TIM7)) {
xPortSysTickHandler();
LL_TIM_ClearFlag_UPDATE(TIM7);
