ryan87 wrote on Monday, April 21, 2014:
Dear FreeRTOS community,
I have a problem with FreeRTOS, which drives me mad for the last days/weeks. My simplified situation is now:
I have a custom board which works fine with multiple STM32 (please exclude the custom board from the reasons of my problem). Two are communicating via USART. So the faulting STM32 usually just receives USART messages and writes an event into a queue. A handler task (Prio 4) then processes the event. configMAX_PRIORITIES set to 5. I disabled all the other processing stuff on that uC.
This concept runs fine and smooth, most of the time.
After some random time, between 5-30mins, the handler task is no longer executed.
Debugging shows that:
uxTopReadyPriority = 0
and
pxReadyTasksLists[4]->uxNumberOfItems = 1
pxIndex shows that this is my handler task, ready and waiting to be executed.
As there is no other task running at prio 4 my handler task is never executed.
I tried this with FreeRTOS v7.2.0 and v8.0.0, configASSERT defined (not hit though).
Is this a bug in FreeRTOS? How can uxTopReadyPriority become 0 when there is a ready task?
I can futher investigate this issue if somebody can tell me what I should be looking for. I am currently not very much into the FreeRTOS source code.
My config is as follows:
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configTICK_RATE_HZ ( ( portTickType ) 1000 )
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 5 )
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 128 )
#define configCPU_CLOCK_HZ ( ( unsigned long ) 168000000 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 54 * 1024 ) )
#define configMAX_TASK_NAME_LEN ( 16 )
#define configIDLE_SHOULD_YIELD 0
#define configUSE_MUTEXES 1
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_STATS_FORMATTING_FUNCTIONS 1
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xQueueGetMutexHolder 1
/* This is the raw value as per the Cortex-M3 NVIC. Values can be 255
(lowest) to 0 (1?) (highest). */
#define configKERNEL_INTERRUPT_PRIORITY 255
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 0x40 /* equivalent to priority 4. */
/* This is the value being used as per the ST library which permits 16
priority values, 0 to 15. This must correspond to the
configKERNEL_INTERRUPT_PRIORITY setting. Here 15 corresponds to the lowest
NVIC value of 255. */
#define configLIBRARY_KERNEL_INTERRUPT_PRIORITY 15
// Software Timers
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY 1
#define configTIMER_QUEUE_LENGTH 10
#define configTIMER_TASK_STACK_DEPTH 512
#ifdef DEBUG
#include "util/log.h"
#define configASSERT(x) if( ( x ) == 0 ) { Log(0); while(1); }
