mindthomas wrote on Sunday, January 22, 2012:
Hi everybody.
I am new to FreeRTOS and have been looking hard on the internet to find a simple example with some LEDs blinking using the tasking feature in FreeRTOS, but I haven’t been able to find it.
So I started ripping off everything unnecessary from the CORTEX_STM32F103_GCC_Rowley demo, though I would actually like to use Ride7!
After much struggling I finally managed to compile with the standard Startup and Script file - I don’t know if I should make any changes?
But of course it didn’t work. As I have read on different posts the problem seems to lie in the StdPeriph and CMSIS. Though I am using version 3.5.0 of StdPeriph which includes version 3.1.0 of the CMSIS. Is this supposed to work or not?
After some debugging I have managed to not getting it into Hard Fault but instead it stops at executing the assembler lines in the vPortStartFirstTask routine.
I would like to know if any of you have a Blink example for the new/most recent version of the StdPeriph - or something around that version?
Thank you
Best Regards
Thomas Jespersen
