embeddedoli wrote on Thursday, November 17, 2016:
we are using a STM32F0 with FreeRTOS. Code was generated using the ST CubeMX and therefore the ST HAL is implemented as well.
We have FreeRTOS running in tickless idle mode and several task / peripherals. As our overall system was designed to rely on the systick and/or the accuracy of the FreeRTOS wait/delay/suspend features we run into problems if anything corrupts the system time.
The HAL uses a timer as timebase generating a tick every ms. Same for FreeRTOS - we expect the systick to increase by 1 each ms.
At the very moment we figured out that sometimes we run into a SPI error condition. In this condition the HAL waits for 50ms for a certain flag (that will not be changed) and runs into a timeout after (all in the ISR). We absolutely understand that this is not a desired behaviour but the HAL is implemented that way.
But from this behaviour we figured out a problem that seems bigger than that. The systick in idle mode seems to miss all the time that is passed in an ISR. So even if all our interrupts are handled within several µs we miss those times on the system clock. That leads to the problem that those missed times summ up to a huge drift of about 100ms each 10s runtime. This highly depends on the amount and the time passed in the interrupts that occure during the sleep.
If we disable the tickless idle feature our power consumption goes up but we see a better tick. It seems like in this case we only miss interrupts that are longer than 1ms - but I’m not sure about this. We know that the drift in time is smaller without the tickless idle feature but if the huge lock in the SPI ISR occures we still miss those 50ms on the clock.
We do not understand why the systick misses the times of the interrupts. We understand that as long as an interrupt is active no change to the systick can be achieved but we do not understand why the missed time is not corrected as soon as the next “tick correction” takes place (probably directly after the ISR is handled)
Are any of my assumptions wrong? Is there anything we can do about this issue?
So there are two issues:
1.) Drift in systick in tickless idle mode
2.) All time passed in an ISR is lost for the sysclock
We are using the latest Cube HAL (1.6.0) for the STM32F072 and the FreeRTOS 8.2.3.
