anonymous wrote on Monday, May 27, 2013:
I experiencing a problem during debugging with the StateViewer for eclipse. Using the OpenRTOS Task Table(DSF) I cannot see Event Objects on which are tasks blocked (the Not known message). However the Queue Table(DSF) shows me all of the semaphores/mutexe/queues. Even those on which the tasks are blocked.
My configuration is:
FreeRTOS V7.4.0
#define configQUEUE_REGISTRY_SIZE 256
Juno Service Release 2 Build id: 20130225-0426
C/C++ GDB Hardware Debugging 7.0.0.201302132326 (DSF)
WHIS StateViewer 2.0.4.201212071112
Segger J-Link v6.42 GDB
Ubuntu 12.04
java version “1.7.0_21”
MCU LPC1788
What should I check more? I mean e.g. log of the GDB communication…
I am using -fdata-sections and -ffunction-sections. Is it possible that the compiler would optimized the item from TCB (task control block) out?
Best
Martin
