tjohansen wrote on Wednesday, July 01, 2009:
Hallo
Im using FreeRTOS on a LPC2478 ARM7 microcontroller.
I have a question recarding stack sizes in my startup file.
Im using KEIL uVision as compiler and mem scheme 2 as memory manager.
As I understand, then the heap (in heap_2.c) is where createTask takes a chunk out every time a task is created. When a task is created the tasks stack size must be supplied. So the combined stack sizes of all the tasks must be smaller then the heap size, incl some task info (defined with configTOTAL_HEAP_SIZE). ???
The task runs in user mode (ARM7 CPU mode). In the startup.s file I can allocate stacks for each processor mode. So, if I’m right, then the user stack size in my startup.s file, must be at least my heap size? Or must it just be minimum my greates task stack size??
/Thomas
