tjohansen wrote on Tuesday, March 24, 2009:
Hallo
I may have some stack/heap problem!?? But im not sure.
Im using the latest FreeRTOS on my LPC2478. I have 5 tasks and they are working fine.
But know I whant to add some graphics task to my project. So I create a new task, which draw some graphics in my framebuffer in a given interval. But when the task runs, then I get an Abort exception. If I check the excpetion cause and extract the assembly where it happens, then its in the context switch rutine.
What I can see in the debugger before the exception(Keil uVision), a structure passed to a graphics function is suddenly out of scope… So when the function returns I get the data abort exception.
My guess is that maybee my stack is to small? The graphics function uses many bytes of RAM. Could that be a the cause?
If I call the graphics function from the main, before the scheduler is started, then there is no problem, but when called from the task I get an exception.
Does tasks run in supervisor mode? or user mode?
This is my stack and heap setup:
UND_Stack_Size EQU 0x00000008
SVC_Stack_Size EQU 0x00000400
ABT_Stack_Size EQU 0x00000008
FIQ_Stack_Size EQU 0x00000008
IRQ_Stack_Size EQU 0x00000400
USR_Stack_Size EQU 0x00000008
ISR_Stack_Size EQU (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size +
FIQ_Stack_Size + IRQ_Stack_Size)
AREA STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem SPACE USR_Stack_Size
__initial_sp SPACE ISR_Stack_Size
Stack_Top
;// <h> Heap Configuration
;// <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF>
;// </h>
Heap_Size EQU 0x00000000
AREA HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem SPACE Heap_Size
__heap_limit
If I look in my Startup.s file, I do not set the user mode stack pointer? Schouldnet I do that?
; Setup Stack for each mode ----------------------------------------------------
LDR R0, =Stack_Top
; Enter Undefined Instruction Mode and set its Stack Pointer
MSR CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #UND_Stack_Size
; Enter Abort Mode and set its Stack Pointer
MSR CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #ABT_Stack_Size
; Enter FIQ Mode and set its Stack Pointer
MSR CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #FIQ_Stack_Size
; Enter IRQ Mode and set its Stack Pointer
MSR CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #IRQ_Stack_Size
; Enter Supervisor Mode and set its Stack Pointer
MSR CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #SVC_Stack_Size
EXPORT __initial_sp
; Enter User Mode and set its Stack Pointer
; MSR CPSR_c, #Mode_USR
; IF :DEF:__MICROLIB
; EXPORT __initial_sp
; ELSE
; MOV SP, R0
; SUB SL, SP, #USR_Stack_Size
; ENDIF
; Enter the C code -------------------------------------------------------------
IMPORT __main
LDR R0, =__main
BX R0
IF :DEF:__MICROLIB
EXPORT __heap_base
EXPORT __heap_limit
ELSE
; User Initial Stack & Heap
AREA |.text|, CODE, READONLY
IMPORT __use_two_region_memory
EXPORT __user_initial_stackheap
LDR R0, = Heap_Mem
LDR R1, =(Stack_Mem + USR_Stack_Size)
LDR R2, = (Heap_Mem + Heap_Size)
LDR R3, = Stack_Mem
BX LR
ENDIF
END
/Thomas
