If you really need the array to be on the stack then the stack size will have to be increased to accommodate it. If only one task is going to access the array, or there is some sort of mutual exclusion mechanism to ensure consistent access, then the array can be declared static - which will prevent it being allocated on the stack.
Thx for your answer. I am now using the array as a global array in a task which means it does not occupy stack or heap space, so everything should be fine.
