I’ve got a strange problem on an STM32F4Discovery board which is probably sticky fingers, but has got me fooled. This is FreeRTOS 7.4.0.
I’ve created an extremely simple build (summon-arm-toolchain) with no active tasks. I have
configUSE_IDLE_HOOK
set.
When I set
configCHECK_FOR_STACK_OVERFLOW
to 1, everything is cool, and I can set/trigger a breakpoint in
vApplicationIdleHook
which implies the code is all cushty.
When I set it to 2, I never seem to reach
. I have taken the expansion for
taskSECOND_CHECK_FOR_STACK_OVERFLOW
from
StackMacros.h
and pasted it into
tasks.c
, then replaced the
if (memcmp...
with a
if (1==0)...
which results in
getting called again (and no, I’m not running out of stack, I’ve got breakpoints in there and I’ve tried setting the stack huge with no change).
Hand stepping through
memcmp
from
newlib
doesn’t reveal anything strange going on either. Its getting late and I will have missed something obvious, but wondered if anyone else had seen any similar behaviour?
You are the second person to have this problem - both times it has been with the summon ARM tools. If you can get down to the bottom of the following post you will see that last time it appeared to be some peculiarity with the libraries (or lack of libraries) provided with the tools:
Hmm…I was getting to the point of blaming the environment, but that’s usually an easy get-out when your own code doesn’t work. OK, will investigate further this evening. I have to find out what’s going on, otherwise I’ll feel like I’m building on sand. Happy to snapshot this build/tools and send it to you if it’s useful….there’s nothing in it anyway.
OK, had a quick dig and changed over from the summon (Linaro) toolchain to gcc-arm….used the pre-compiled version to make sure I’ve got something the same as others. Linking with newlib from there resulted in the same behavior but linking with the nano lib (-specs nano.specs) results in a correctly working system.
My guess is that something in the way newlib is built results in some strange alignments and without the same incantations for the app there’s an incompatibility that shows up as the RTOS not scheduling tasks. I don’t really want to be using newlib anyway so for now the solution for me is to move to the nano library. I’ll have a quick peek at the build script for the gcc-arm to see if there’s anything obvious in there - if I see anything I’ll post back for others. In the meantime Richard you might want to note that there may be some issues using newlib (at least without specific incantations on the compile and link lines).
