Is there a recommended way to allow spaces in CLI parameters?
Since they act as the delimiters, my current approach is to use a command with a variable number of arguments, wrap each arg in quotes when sending it over the CLI, and then just do string parsing on the entire passed in command string instead of using FreeRTOS_CLIGetParameter() like I normally would.
Is there a better way?
Thanks
