Hi, I am new to freeRTOS and I am using it with a STM32L476 board (Nucleo-64).
I have created a task and started the scheduler. myTask1 has an infinite while loop.
PortTASK_FUNCTION is a macro, not a function. It is used to declare tasks, like the Idle task. Could the issue be you task wasn’t successfully created so Al that is running is the Idle task?
Since you’re using tskIDLE_PRIORITY for your task you should set #define configIDLE_SHOULD_YIELD 1
in your FreeRTOSConfig.h to give your task a chance to run besides the idle task.
Alternatively bump the prio of your task e.g. to tskIDLE_PRIORITY +1.
