heinbali01 wrote on Thursday, May 16, 2019:
Hi George, let me first ask what you are creating? Is it a TCP server?
Is it a web-server, or a server that responds to questions?
Do I understand correctly that you want to disconnect automatically from a client, once the client doesn’t seem to respond? Are those clients somewhere on the web?
Normally, and in most cases, a TCP connection comes to an end because of a shutdown. All operating systems are programmed to finish the last steps correctly (FIN, FIN+ACK, ACK).
So, using keep-alive messages is an emergency thing, normally only useful when the peer is on the Internet.
I will summarise the two options that you mention:
● ipconfigTCP_HANG_PROTECTION_TIME
(seconds)
when the socket is not yet connected, we can not send keep-alive packets. During that state, a simple timer is used to protect the socket from staying in that phase for ever.
Normally, this timer shouldn’t do much: an active connect is limited in time: it does 3 attempts, and after the last attempt, it gets into an error state eCLOSE_WAIT
● ipconfigTCP_KEEP_ALIVE_INTERVAL
(seconds)
when a connection is idle ( i.e. no data are being sent or received ), the socket will send keep-alive packets. It has a limited use: it is not supported by all routers or TCP clients.
The timing of this process has some randomness: as long as data is being exchanged, the socket is happy. Only after a total silence of ipconfigTCP_KEEP_ALIVE_INTERVAL
seconds, the socket will send a keep-alive message.
A second and third keep-alive message will be sent, each with a fixed time-out of 3 seconds( Yes, hard-coded ).
Note that the low-level keep-alive messages are sent to the other OS, and not to the client. Maybe the client is dead/non-functional, while the OS still responds to the keep-alive messages. In that case, you may get a false OK.
I’don;t know if it’s possible in your case: a better solution is to check the peer’s status on a higher level: by actively polling the client, sending a message of the type “are you alive?”, to which is must respond.
Or make the client responsible: let it send a poll message at least every N seconds.
The best way to test/understand the “keep-alive” behaviour is to create some logging.
