I was porting to SMP v11 FreeRTOS Kernel. My question is regarding portGET_ISR_LOCK() and portRELEASE_ISR_LOCK(). Can they be called from the isr context or will they always be called from the non-isr context?
As such is it fine to implement them from Freertos’s recursive semaphore?
This lock is supposed to provide inter-core synchronization and therefore, cannot be implemented using FreeRTOS synchronization primitives. Usually it is implemented using hardware spin lock. You can refer the following examples:
I looked at the examples you mentioned. XCoreAI implements it using a proprietary function, so that’s not really helpful while RP2040 gave some insight.
I am trying to port to arm R8. But judging from its specifications, it does not have any hardware spinlock. What do you suggest in this case?
