Hi, I started my projekt with RP2040 and FreeRTOS SMP. I use the Eclipse IDE on Windows 10. I’m able to build Release and Debug configurations. With Segger JLink I also can debug. So far so good. But I get a lot of warnigs and 4 errors at the end of the build process.
Finished building: PicoSMP.hex
Invoking: GNU Arm Cross Print Size
arm-none-eabi-size --format=berkeley “PicoSMP.elf”
** text data bss dec hex filename**
** 47000 0 133392 180392 2c0a8 PicoSMP.elf**
Finished building: PicoSMP.siz
21:28:54 Build Failed. 4 errors, 350 warnings. (took 19s.436ms)
One of the warnings is for example:
../FreeRTOS/Source/tasks.c:3646:39: warning: comparison of integer expressions of different signedness: 'UBaseType_t' {aka 'long unsigned int'} and 'BaseType_t' {aka 'long int'} [-Wsign-compare]
3646 | if( x == xCoreID )
Is it normal to get this warning? Or what should I do with the 350 warnings?
Regards
Lothar
