ben_fnr wrote on Friday, February 01, 2008:
Can I ask for a small modification to FreeRTOS. I like the configUSE_TRACE_FACILITY option but I notice you are using sprintf to format the output, which has a rather large overhead by the time the appropriate library functions are included. It is something like 20k under GCC, while the RTOS code that gets included is only around 600 bytes.
As it happens I have my own cut down version of sprintf which of course I can easily substitute in task.c, but of course this will get over written should I upgrade it at any time, so my suggestion would be to add
#ifndef SPRINTF_FUNCTION
#define SPRINTF_FUNCTION sprintf
to the top of task.c, and change
sprintf( pcStatusString, ( portCHAR * ) "%s\t\t%c\t%u\t%u\t%u\r\n", pxNextTCB->pcTaskName, cStatus, ( unsigned int ) pxNextTCB->uxPriority, usStackRemaining, ( unsigned int ) pxNextTCB->uxTCBNumber );
to
SPRINTF_FUNCTION( pcStatusString, ( portCHAR * ) "%s\t\t%c\t%u\t%u\t%u\r\n", pxNextTCB->pcTaskName, cStatus, ( unsigned int ) pxNextTCB->uxPriority, usStackRemaining, ( unsigned int ) pxNextTCB->uxTCBNumber );
that way it can easily be overridden from FreeRTOSConfig.h to point to an alternative function.
