I downloaded the file 160318_FreeRTOS_SiLabs.zip and imported the project in Simplicity Studio IDE v3.
First I had to correct the path of FREERTOS_ROOT variable in project settings.
When I build the project I get the following error:
Field ‘em23VregFullEn’ could not be resolved in /RTOSDemo/SiLabs_Source/emlib/em_emu.c line 756 Semantic Error
‘EMU_EM23Init_TypeDef’ has no member named 'em23VregFullEn in /RTOSDemo/SiLabs_Source/emlibem_emu.c line 756 C/C++ Problem
That should not be necessary - the variable is set to “${PROJECT_LOC}......”, which is a path relative to the project directory, so unless you changed the directory structure, or didn’t follow the import instructions provided on the website exactly, it should just work.
What did you need to change it to?
What happens if you right click on the ‘EMU_EM23Init_TypeDef’ type in the source code (the location of which is part of the error message), then select “Open Declaration” from the pop up menu. In my set up I’m taken to the following definition:
typedef struct
bool em23VregFullEn;/**< Enable full VREG drive strength in EM2/3 */
} EMU_EM23Init_TypeDef;
which, as you see, does have a em23VregFullEn variable.
Note, the header file this extract is taken from is part of the Simplicity studio directory structure, it is not part of the FreeRTOS code. Have you installed support for the target you are trying to use in Simplicity Studio (either Giant or Pearl Gecko, I don’t think you said which you were using). If not, that might be your problem.
I have just updated the build instructions to include the following as
the first step:
“Ensure you have Giant and/or Pearl Gecko starter kit support included
in your Simplicity Studio installation, otherwise the project will fail
to build. Support for additional EFM32 devices and starter kits can be
installed using the Simplicity Studio menus.”
Please ensure the following the instructions on importing the project
exactly - I see from the screen shot you have “copy projects into
workspace” checked, which it should not be.
Be possible to compile For the STK3600?
If yes, what are the steps to follow?
That is becoming a tools issue, rather than a FreeRTOS support issue,
but if the chip on the STK3600 is the same as that on the starter kit
then I would guess the only change needed would be the pin used to
toggle the LED.
Starting from the example for the STK3700 board I created a demo for STK3600 board.
I attached the project that mast be unpacked in the folder “FreeRTOS_SiLabs\freeRTOS\Demo”.
I see the LED0 flashing.
It’s can insert a kind of “task table” in Simplicity Studio ?
If Simplicity Studio uses GDB then you should be able to use the Eclipse
StateViewer plug-in available from the http://www.highintegritysystems.com website.
