john1953 wrote on Tuesday, August 13, 2013:
I am trying to do a very simple transmit and receive a char on UART0 I have this for transmit:
void UART_Task_Init()
LPC_UART_TypeDef *UARTx = (LPC_UART_TypeDef *) LPC_UART0;
UART_CFG_Type UARTConfigStruct; /* UART Configuration structure variable */
UART_FIFO_CFG_Type UARTFIFOConfigStruct; /* UART FIFO configuration Struct variable */
/* Initialize UART Configuration parameter structure to default state:
* Baudrate = 9600bps, 8 data bit, 1 Stop bit, None parity */
UART_ConfigStructInit(&UARTConfigStruct);
/* Set Baudrate to 115200 */
//UARTConfigStruct.Baud_rate = 115200;
/* Initialize UART0 peripheral with given to corresponding parameter */
UART_Init(LPC_UART0, &UARTConfigStruct);
#if 1
/* Initialize FIFOConfigStruct to default state:
* - FIFO_DMAMode = DISABLE
* - FIFO_Level = UART_FIFO_TRGLEV0
* - FIFO_ResetRxBuf = ENABLE
* - FIFO_ResetTxBuf = ENABLE
* - FIFO_State = ENABLE
UART_FIFOConfigStructInit(&UARTFIFOConfigStruct);
/* Initialize FIFO for UART0 peripheral */
UART_FIFOConfig(UARTx, &UARTFIFOConfigStruct);
/* Enable UART Transmit */
UART_TxCmd(UARTx, ENABLE);
Followed by a:
UART_Send(UARTx, (uint8_t *)string, strlen(string), BLOCKING);
It seems to try and transmit:
UART_SendByte(UARTx, (*pChar++));
the first character and then times out.
Is this the right path?
Also do you have a example receive?
I could not find serial example for 1778.
