I would like the following help:
I have a complex hardware that works with ESP32 S3 16MB of Ram and ESP IDF 5
The function of this hardware is to connect to Wifi and ping different IP devices.
This ping command is not done multiple times. I mean that I don’t call the ping function several times. I wait for one ping to finish and start another.
I did it this way, because I understand that it was safer.
However, on this same hardware I have two MQTT connections, one connection sends information every 1 minute and another connection listens to a topic that can receive data every moment.
My question is is this connection to the wifi hardware a system restriction? Do I have to apply a Semaphoro or event group to each thing?
Currently MQTT and Ping run at the same time. But I don’t know if it’s correct.
What do you think ?
I’m going to paste a part of the code here so you can understand a little of the context and also a photo of the product.
void v_Pingador(void *parameters) {
while(1){
for (int i = 0; i < MAX_IP_COUNT; i++) {
if (Device[i].Servico != NULL && strcmp(Device[i].Servico, "ping") == 0) {
if(f_Ipv4Valid(Device[i].ip_addresses)){
xEventGroupWaitBits(xEventGroupWifi, WIFI_BIT_0, pdFALSE, pdFALSE, portMAX_DELAY);
xSemaphoreTake(SemaphorePing, portMAX_DELAY);
f_Ping((void *)&Device[i]);
void f_CoreSubscribe(){
if (Device[i].Servico != NULL && strcmp(Device[i].Servico, "mqtt") == 0) {
if(Device[i].topico != NULL){
if(f_ValidaTopico(Device[i].topico)){
f_subscribe(Device[i].topico);
void v_Display_0(void *pvParameters) {
int8_t Alarme_Device;
int32_t TimeOut_Count[MAX_IP_COUNT];
unsigned long received_item;
char ms_str[22];
char ms_str2[26];
while(1) {
char * receivedMqtt;
for (int i=0; i<MAX_IP_COUNT;i++){
xEventGroupWaitBits(EventG_Display, BIT_0, pdFALSE, pdFALSE, portMAX_DELAY);
if (Device[i].xQueue!=NULL){
if (Device[i].Servico != NULL && strcmp(Device[i].Servico, "ping") == 0){
if (xQueueReceive(Device[i].xQueue, &received_item, 0)) {
if (received_item != UINT32_MAX){
snprintf(ms_str, sizeof(ms_str), "Tempo - %ldms", received_item);
f_Mostra(ms_str, Device[i].ip_addresses, Device[i].Device_Name, Clear_OFF, i);
TimeOut_Count[i] = 0;
}else{
snprintf(ms_str2, sizeof(ms_str2), "%s - Outs:%lu", Device[i].Device_Name, TimeOut_Count[i]+1);
f_Mostra("TIME OUT!!", Device[i].ip_addresses, ms_str2, Clear_ON, i);
TimeOut_Count[i]++;
EventBits_t bits = xEventGroupGetBits(EventG_Alarme);
if(TimeOut_Count[i]>Alarme_NumAtivarStatus && !(bits & BIT_0)){
xEventGroupSetBits(EventG_Alarme, BIT_0);
f_Led(LED_VERDE, Led_Desliga);
urlFinal = f_urlFinal(AlarmeWebHookURL_val, AlarmeWebHookText_val, Device[i].Device_Name, Device[i].ip_addresses);
Alarme_Device = i;
AlarmeSonoroSuprimir = true;
}else if(i == Alarme_Device && TimeOut_Count[i] == 0 && (bits & BIT_0)){
xEventGroupClearBits(EventG_Alarme, BIT_0);
AlarmeSonoroSuprimir = false;
f_Led(LED_VERDE, Led_Liga);
ESP_LOGW(TAG, "Led Verde...ligado");
} else if (Device[i].Servico != NULL && strcmp(Device[i].Servico, "mqtt") == 0){
if (xQueueReceive(Device[i].xQueue, &receivedMqtt, 0)) {
f_Mostra(receivedMqtt, Device[i].topico,Device[i].Device_Name, Clear_OFF, i);
else{
if (Texto_Display_Vazio != NULL && (strlen(Texto_Display_Vazio)>3)) {
f_Mostra("", "", Texto_Display_Vazio, Clear_OFF, i);
//ESP_LOGW(TAG, "Device[%i]", i);
vPortYield();
and
The ping code:
void on_ping_success(esp_ping_handle_t hdl, void *args) {
uint32_t elapsed_time_ms;
esp_err_t ret;
ip_addr_t target_addr;
device_t *Device_X = (device_t *)args;
ret = esp_ping_get_profile(hdl, ESP_PING_PROF_TIMEGAP, &elapsed_time_ms, sizeof(uint32_t));
if (ret != ESP_OK) {ESP_LOGE("TAG", "Erro ao obter o tempo decorrido: %d", ret);return;}
ret = esp_ping_get_profile(hdl, ESP_PING_PROF_IPADDR, &target_addr, sizeof(ip_addr_t));
if (ret != ESP_OK) {ESP_LOGE("TAG", "Erro ao obter o endereço IP alvo: %d", ret);return;}
xQueueSend(Device_X->xQueue, &elapsed_time_ms, 100);
void on_ping_timeout(esp_ping_handle_t hdl, void *args) {
esp_err_t ret;
uint32_t Max = UINT32_MAX;
xQueueSend(Device_X->xQueue, &Max, 100);
void on_ping_end(esp_ping_handle_t hdl, void *args) {
esp_err_t ret;
ret = esp_ping_delete_session(hdl);
if (ret != ESP_OK) {printf("Erro ao encerrar a sessão de ping: %d\n", ret);return;}
xSemaphoreGive(SemaphorePing);
void f_Ping(void *parameters) {
device_t *Device_X = (device_t *)parameters;
if (f_PingValida(Device_X)==false) {xSemaphoreGive(SemaphorePing);return;}
ip_addr_t ip;
ip.u_addr.ip4.addr = esp_ip4addr_aton(Device_X->ip_addresses);
ip.type = IPADDR_TYPE_V4;
esp_ping_config_t ping_config = {
.target_addr = ip, // Endereço IP do host a ser pingado
.count = Device_X->count, // Número de pacotes a serem enviados
.interval_ms = Device_X->interval_ms, // Intervalo entre os envios de pacotes (em milissegundos)
.data_size = Device_X->data_size, // Tamanho dos dados do pacote ICMP
.timeout_ms = Device_X->timeout_ms, // Tempo limite para esperar por uma resposta (em milissegundos)
.tos = Device_X->tos, // Tipo de Serviço (TOS) para o pacote IP
.ttl = Device_X->ttl, // Tempo de Vida (TTL) do pacote IP
//.interface = NULL, // Interface de rede a ser usada para o ping (NULL para usar a interface padrão)
.task_stack_size = 3000,
.task_prio = 5
esp_ping_callbacks_t ping_callbacks = {.on_ping_success = on_ping_success,.on_ping_timeout = on_ping_timeout,.on_ping_end = on_ping_end,.cb_args = (void *)Device_X};
esp_ping_handle_t ping_handle;
esp_err_t ret = esp_ping_new_session(&ping_config, &ping_callbacks, &ping_handle);
if (ret != ESP_OK) {printf("Erro ao criar a sessão de ping: %d\n", ret);ESP_LOGE(TAG, "IP[%s]", Device_X->ip_addresses);xSemaphoreGive(SemaphorePing);return;}
ret = esp_ping_start(ping_handle);
if (ret != ESP_OK) {printf("Erro ao iniciar o ping: %d\n", ret);ESP_LOGW(TAG, "IP[%s]", Device_X->ip_addresses);xSemaphoreGive(SemaphorePing);return;}
The MQTT Code:
//---MQTT 1--------------------------------------------------------------------------------------------------------------
static void mqtt_event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data){
ESP_LOGD(TAG, "Event dispatched from event loop base=%s, event_id=%" PRIi32 "", base, event_id);
esp_mqtt_event_handle_t event = event_data;
esp_mqtt_client_handle_t client = event->client;
switch ((esp_mqtt_event_id_t)event_id) {
case MQTT_EVENT_CONNECTED:
ESP_LOGI(TAG, "MQTT_EVENT_CONNECTED");
f_CoreSubscribe();
break;
case MQTT_EVENT_DISCONNECTED:
ESP_LOGI(TAG, "MQTT_EVENT_DISCONNECTED");
break;
case MQTT_EVENT_DATA:
char *topic = strndup(event->topic, event->topic_len);
char *data = strndup(event->data, event->data_len);
if (topic && data) {f_SendDataMqtt(topic, data);} else {ESP_LOGE(TAG, "Falha ao alocar memória para tópico ou payload");}
free(topic);free(data);
break;
case MQTT_EVENT_ERROR:
ESP_LOGI(TAG, "MQTT_EVENT_ERROR");
if (event->error_handle->error_type == MQTT_ERROR_TYPE_TCP_TRANSPORT) {
log_error_if_nonzero("reported from esp-tls", event->error_handle->esp_tls_last_esp_err);
log_error_if_nonzero("reported from tls stack", event->error_handle->esp_tls_stack_err);
log_error_if_nonzero("captured as transport's socket errno", event->error_handle->esp_transport_sock_errno);
ESP_LOGI(TAG, "Last errno string (%s)", strerror(event->error_handle->esp_transport_sock_errno));
break;
default:
ESP_LOGI(TAG, "Other event id:%d", event->event_id);
break;
//---MQTT 2--------------------------------------------------------------------------------------------------------------
static void mqtt_event_handler_out(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data){
esp_mqtt_client_subscribe(client, TOPICO_OTA, 0);
esp_mqtt_client_subscribe(client, TOPICO_URL, 0);
esp_mqtt_client_subscribe(client, f_topico(TOPICO_LICENCA), 0);
f_mqttPublica(f_topico(zMQTT_sufixo), f_prepJsonConfig(mqtt_ON), cMqttOut);
f_mqttPublica(f_topico(zMQTT_sufixo_Config), f_prepJsonConfig(mqtt_Config), cMqttOut);
break;
break;
ESP_LOGI(TAG, "MQTT_EVENT_DATA");
printf("TOPIC=%.*s\r\n", event->topic_len, event->topic);
printf("DATA=%.*s\r\n", event->data_len, event->data);
//Testa qual tópico foi recebido e começa a fazer as coisas conforme o tópico
if (strncmp(event->topic, TOPICO_OTA, event->topic_len) == 0) {
f_otaMQTT(event->topic, event->topic_len, event->data, event->data_len);
if (strncmp(event->topic, TOPICO_URL, event->topic_len) == 0) {
ESP_LOGW(TAG, "TOPICO URL");//Desenvolver ainda...
if (strncmp(event->topic, f_topico(TOPICO_LICENCA), event->topic_len) == 0) {
cJSON *token = cJSON_GetObjectItem(cJSON_Parse((char *)event->data), "token");
if (!cJSON_IsString(token)){ESP_LOGE(TAG, "Erro na leitura do json");}
f_nvsSet(zTokenTemp, token->valuestring, false);
xTaskCreatePinnedToCore(v_InsertLicenca, "v_InsertLicenca", 8000, NULL, tskIDLE_PRIORITY, NULL, tskNO_AFFINITY);
break;
break;
default:
break;
void f_mqttPublica(const char * topico, const char * payload, esp_mqtt_client_handle_t handle){
EventBits_t bits = xEventGroupWaitBits(xEventGroupWifi, WIFI_BIT_0, pdFALSE, pdFALSE, 200);
if((bits & WIFI_BIT_0)){
int len = strlen(payload);
//xSemaphoreTake(SemaphorePing, portMAX_DELAY);
int resp = esp_mqtt_client_publish(handle, topico,payload,len,0,0);
if (resp==0){
ESP_LOGI(TAG, "JSON publicado via MQTT. Com sucesso");
}else if(resp<0){
ESP_LOGE(TAG, "JSON publicado via MQTT. Erro na publicação");
//xSemaphoreGive(SemaphorePing);
extern const uint8_t ca_cert_pem_start[] asm("_binary_ca_cert_pem_start");
extern const uint8_t ca_cert_pem_end[] asm("_binary_ca_cert_pem_end");
void f_setupMQTT(void){
Dados_Mqtt_t DadosMqtt, DadosMqttout;
if(f_DadosMqtt(&DadosMqtt) == ESP_OK){
ESP_LOGW(TAG, "MQTT");
//ESP_LOGW(TAG, "cert:%s", DadosMqtt.mqtt_cert);
//ESP_LOGW(TAG, "cert:%i", DadosMqtt.mqtt_cert_len);
esp_mqtt_client_config_t mqtt_cfg = {
.broker.address.uri = DadosMqtt.mqtt_server,
.broker.address.port = DadosMqtt.mqtt_port,
.broker.verification.certificate = (const char *)ca_cert_pem_start,
.broker.verification.certificate_len = (ca_cert_pem_end - ca_cert_pem_start),
//.broker.verification.certificate = DadosMqtt.mqtt_cert,
//.broker.verification.certificate_len = DadosMqtt.mqtt_cert_len,
.credentials.username = DadosMqtt.mqtt_user,
.credentials.authentication.password = DadosMqtt.mqtt_pass,
.credentials.client_id = "enervision",
.session.last_will.msg = f_prepJsonConfig(mqtt_OFF),
.session.last_will.msg_len = strlen(f_prepJsonConfig(mqtt_OFF)),
.session.last_will.topic = f_topico(zMQTT_sufixo),
.session.last_will.retain = true,
.session.last_will.qos = 1,
.session.keepalive = 2
//Fazer isso no futuro - v.2.0 //Não conectou ... Busca o backup por OTA ?
//Antes de buscar a conexão via backup, conferir conexões, ping, verificar se o dns
EventBits_t bits = xEventGroupWaitBits(xEventGroupWifi, WIFI_BIT_0, pdFALSE, pdFALSE, pdMS_TO_TICKS(40000));
client = esp_mqtt_client_init(&mqtt_cfg);
esp_mqtt_client_register_event(client, ESP_EVENT_ANY_ID, mqtt_event_handler, NULL);
esp_mqtt_client_start(client);
if(f_DadosMqttout(&DadosMqttout) == ESP_OK){
ESP_LOGW(TAG, "MQTT OUT");
esp_mqtt_client_config_t mqtt_cfg_out = {
.broker.address.uri = DadosMqttout.mqtt_server,
.broker.address.port = DadosMqttout.mqtt_port,
.credentials.username = DadosMqttout.mqtt_user,
.credentials.authentication.password = DadosMqttout.mqtt_pass,
.credentials.client_id = f_serialNumber(),
cMqttOut = esp_mqtt_client_init(&mqtt_cfg_out);
esp_mqtt_client_register_event(cMqttOut, ESP_EVENT_ANY_ID, mqtt_event_handler_out, NULL);
esp_mqtt_client_start(cMqttOut);
My Setup Screen:
My product:
