I need to send and receive changing sensor data through queue, maybe someone have some basic examples, I am not really experienced?
Thank you.
Thank you.
Have you checked the API docs, examples in the download, and the free to download book?
Do you really need a queue, or you just want to send the sensor’s data? In the latter you might use messages buffers instead of queues.
I wrote an entry on the topic. Although it’s written in spanish you can follow the source codes (all names in the code are in english):
For the same case, if you need to send integer values in a task-to-task fashion, then you should try the Direct to task notifications mechanism. I also write an entry on the topic:
http://fjrg76.com/2021/01/31/notificaciones_i/
Greetings!
