Sending Struct
I changed the demo project of FreeRTOS and i can get only first element of struct.
> void main_blinky( void )
>     printf( "\r\nStarting the blinky demo. Press \'%c\' to reset the software timer used in this demo.\r\n\r\n", mainRESET_TIMER_KEY );
> 	/* Create the queue. */
> 	xQueue = xQueueCreate( mainQUEUE_LENGTH, sizeof( uint32_t ) );
> 	if( xQueue != NULL )
> 		/* Start the two tasks as described in the comments at the top of this
> 		file. */
> 		xTaskCreate( prvQueueReceiveTask,
> 					"Rx",
> 					configMINIMAL_STACK_SIZE,
> 					NULL,
> 					mainQUEUE_RECEIVE_TASK_PRIORITY,
> 					NULL );
> 		xTaskCreate( prvQueueSendTask, "TX", configMINIMAL_STACK_SIZE, NULL, mainQUEUE_SEND_TASK_PRIORITY, NULL );
> 		vTaskStartScheduler();
> 	for( ;; );
> typedef struct {
>     int initialPosition[2];  // x and y coordinates
>     int velocity[2];         // V_x and V_y components
>     float gaussianNoise[2];  // O_x and O_y components
> } Measurments;
> static void prvQueueSendTask( void *pvParameters )
> TickType_t xNextWakeTime;
> const TickType_t xBlockTime = mainTASK_SEND_FREQUENCY_MS;
> Measurments data;
> 	( void ) pvParameters;
> 	xNextWakeTime = xTaskGetTickCount();
> 	for( ;; )
>         data.initialPosition[0] = 10;   // Example: x coordinate
>         data.initialPosition[1] = 30;   // Example: y coordinate
>         data.velocity[0] = 5;           // Example: V_x
>         data.velocity[1] = 2;           // Example: V_y
>         data.gaussianNoise[0] = 0.1f;   // Example: O_x
>         data.gaussianNoise[1] = 0.2f;   // Example: O_y
>         vTaskDelayUntil( &xNextWakeTime, xBlockTime );
> 	xQueueSend( xQueue, &data, 0U );
> static void prvQueueReceiveTask( void *pvParameters )
> uint32_t ulReceivedValue;
> Measurments receivedData;
> 	for( ;; )
> 		xQueueReceive( xQueue, &receivedData, portMAX_DELAY );
>         taskENTER_CRITICAL();
>             printf("Received Data:\r\n");
>             printf("Initial Position: x=%d, y=%d\r\n", receivedData.initialPosition[0], receivedData.initialPosition[1]);
>             printf("Velocity: V_x=%d, V_y=%d\r\n", receivedData.velocity[0], receivedData.velocity[1]);
>             printf("Gaussian Noise: O_x=%f, O_y=%f\r\n", receivedData.gaussianNoise[0], receivedData.gaussianNoise[1]);
>         taskEXIT_CRITICAL();
Output:
Received Data:
Initial Position: x=10, y=-858993460
Velocity: V_x=-858993460, V_y=-858993460
Gaussian Noise: O_x=-107374176.000000, O_y=-107374176.000000
This line is the problem. You need to tell the size of each item at the time of queue creation -
xQueue = xQueueCreate( mainQUEUE_LENGTH, sizeof( Measurments) );
See the detailed documentation here - FreeRTOS - FreeRTOS queue API functions, including source code functions to create queues, send messages on queues, receive messages on queues, peek queues, use queues in interrupts..
