verretj wrote on Monday, December 01, 2008:
I’m trying to make a serial driver. Therefore I have to send a message from an ISR.
This message sometimes awake a different task from the one it is interrupting, and sometimes the same task that was interrupted.
Referring to the documentation I have to use taskYIELD_FROM_ISR () when the task has been awaken. But It is apparently not defined in the code.
How can I do then.
I tried without it but I can merely send an receive characters once.
And I tried with taskYIELD and portYIELD_FROM_ISR() which does not work at all
What should I do and where is this taskYIELD_FROM_ISR () defined?
